cautionary tale here
leftwinger57
I thought maybe my 2Bs finally went south w/ the x-overs still to be done. While turning cds which I find the cleanest sound out of all my sources I started to hear noises that I never heard before. Not music mind you but really offending noises. When I got these home originally the x-over standoffs were broken on both sets. The x-overs were effectively flying in air. When I did most of my mechanical mods I thought I resecured them w/ small ty-raps and a foam sheet in between the coil. I luckily opened just for the hell of it the whole right side and sure enough 2 big glaring problems. In my haste this cross-over was not secured and then what I think caused all this out of phase sound was the green wire was off the 6511 mid. All secured and back buttoned up and now they sound like before or as they should.
Now, I know I have harped on doing the x-overs but sending them out at this time is not financially possible. Is there a real time moment that one knows the x-overs are really toast?
I have never had a XO just completely give out. That being said my growing speaker collection only dates back to early seventies and up... what I have noticed is the marked improvement in sound when upgrading XO parts with new higher quality repacements with far better tolerances than were available back then.
Lew, I can send you some Polk standoffs, so this doesn't keep happening.Home Theater/2 Channel:
dhsspeakerservice.com/ -
They're toast.leftwinger57 wrote: »I have harped on doing the x-overs but sending them out at this time is not financially possible. Is there a real time moment that one knows the x-overs are really toast?
Can you solder? -
Sounds like its time to bite the bullet. I'm sure you could do it yourself. I did my 7s. It wasn't really difficult, just take your time. There is plenty of advice here to get you through.HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
Rt35i Surrounds/Cs1000p Center/SVS BP1000 Sub
2CH - B&K MC-101 pre/B&K EX-442 amp/NAD 2400 amp
Polk SDA1C, Polk Monitor 7, New Large Advents and Polk RTA 8T
BR - Yamaha CR800/Polk monitor 5 -
do what i did...find some old stereo equipment that no one wants and tear it apart...use it to practice desoldering then solder it all back together...once you get your technique down its not really hard...but patience is key...don't just wing it, have a plan...Marantz 1152 DC- Denon DP 1200, Soundsmith Carmen MKII- ADS L980 - Blue Jeans IC's
Get the parts,, pull em out,,I'm sure that someone here will get it done.JC approves....he told me so. (F-1 nut)
Send Trey a message , he will get it done if you don't feel comfortable doing it.Home Theater
Two Channel
Oppo 105D BAT VK-500 w/BatPack SDA SRS 2.3 Dreadnought Squeezebox Touch Apple TV -
Thanks I've hasseled Trey to no end. I just don't have the cash right now and that's the only factor limiting me doing this. Yes I've picked up odds and ends like lps and the Nikko but nothing that come close to the cost of sending them out which is my first choice. I can solder well actually from my alarm installing days and have both gas and electric guns. Following Gimpods site (and what a freakin site) is the best road map anyone could want for a diyer. Again I need things tested and since I know nothing of tolerances or values I have to send them out. There is something to be said of having the satisfaction of doing it youself but this I'll leave to Trey. Btw does anyone have Trey's shipping address in N.C. somewhere?2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
Tolerances or value's...?
not sure what you mean...
just replace value for valueMarantz 1152 DC- Denon DP 1200, Soundsmith Carmen MKII- ADS L980 - Blue Jeans IC's -
If your cash strapped for now just enjoy your polks. Sounds like you have diagnosed the problem and they sound good to you again. I have sets of **** speakers that you probably wouldn't even make your dog listen to.
There is someone here on the forum that can do an excellent job on your crossovers at a reasonable price. He did mine and I was very happy with his work. Professional and fast service. See my signature line.leftwinger57 wrote: »Thanks I've hasseled Trey to no end. I just don't have the cash right now and that's the only factor limiting me doing this. Yes I've picked up odds and ends like lps and the Nikko but nothing that come close to the cost of sending them out which is my first choice. I can solder well actually from my alarm installing days and have both gas and electric guns. Following Gimpods site (and what a freakin site) is the best road map anyone could want for a diyer. Again I need things tested and since I know nothing of tolerances or values I have to send them out. There is something to be said of having the satisfaction of doing it youself but this I'll leave to Trey. Btw does anyone have Trey's shipping address in N.C. somewhere?- SDA 2BTL · Sonicaps · Mills resistors · RDO-198s · New gaskets · H-nuts · Erse inductors · BH5 · Dynamat
- Crossover upgrades by westmassguy
- Marantz 1504 AVR (front speaker pre-outs to Adcom 555)
- Adcom GFA-555 amp · Upgrades & speaker protection added by OldmanSRS
- Pioneer DV-610AV DVD/CD player
- SDA CRS+ · Hidden away in the closet
Lew, you can solder so you can do this. Very simple - get the parts list off the schematics for your speaker, order caps and resistors of the same value (you can leave the inductors alone for now to save money, though replacing them with higher quality ones makes for an audible improvement), and do one circuit board at a time. You don't need to use Gimpod's boards if you're short of cash, just used the originals.
By doing one board at a time you can use the other for reference. Remove/replace one component at a time. Easy, peasy.
I'm sure WMG and VR3 do quality work, but if you're trying to save $, DIY is the way to go."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
Again guys thanks. The noise is back and couldn't take it any more so I pulled the x-overs just a few minutes ago. Believe it or not I had a box w/ both Trey's address and mine all ready to go for months. They are packed just need some cash and off they go. Then we'll see what you all are talking about. It's a shame they are my favorite set but that's why I have 3 others to bounce from.2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
New member here and I've really enjoyed reading the posts. I had Monitor 7s back in high school (long gone now) and just found a pair in a GW for $15. Took'm home and they sounded bad due to frozen mids. No surprise there. Pulled the 6502s and found they were dated 1990.
Two weeks later I'm at the dump and found a pair of RTA 12s! At the dump?!?! Didn't know what they were at first but recognized the Polk format from adds growing up. One had a hole in the tweeter and I almost thought "why bother." But why not try'm out.
Asked the guy and he said "sure, take'm home" hooked them up and they sounded bad for three seconds, then not so bad. Minute later they sounded almost good. Then they sounded better than my PSB B2s and my JBL LSR 308s. I honestly could not believe it! Started doing web searches and am guessing they are 12Bs w Peerless tweeters (both have holes)
Each have a frozen mid and I tried to pull one. Removed screws and tried to pull it off but could not and did not want to damage anything. So I've been listening to them for a week now and still can't believe how good they sound (with two seized mids!!).
I've read on this site about getting replacement mids from polk but when I called earlier for the M7s they said they did not stock them anymore. Tweeters seem fine and the dust/gunk on the c/o came off w a dry brush and can of air.
So now for the question. Do I get a replacement mids from PE or Madisound or ??? After that do I do the c/o upgrades everyone is talking about? Seriously, these things sound great, but they shouldn't, right? Also, who is Trey in NC who does c/o? I did a search but got no returns
Thanks for all the info over the last weeks and any replies to this post.HT: Marantz NR-1603, Oppo 981, Def Tech SM55, SVS PB-1000
BR: iPad Mini, Audio Engine A5+
2C: Parasound ZDAC V.2, Sony DA80ES, Sony XDR-F1HD, SVS Prime Tower, JSE .6 Infinite Slope
Office: MBAir, Focusrite Scarlett 2i2, JBL LSR-308
Projects: Polk RTA12, Polk Monitor 7, Revox B225CD, BIC 3-TM -
You'll get more responses if you create your own threads for your questions. Call Polk, I'm sure they have something they'd feel comfortable swapping those seized MW6600X's with. If you want to risk it used and shipped, here you go - http://www.ebay.com/itm/LOT-OF-THREE-Polk-MW-6600X-6-5-inch-woofers-for-RTA-SDA-Monitor-series-/281316030059?pt=US_Speaker_Parts_Components&hash=item417fbdf66bafterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk
