Fascinating crossover upgrade
F1nut
F1nut Posts: 52,020
edited April 2014 in 2 Channel Audio
Post edited by F1nut on
  • Face
    Face Posts: 14,340
    edited April 2014
    Other than cringing at the brass binding posts, beautiful work!
    pitdogg2 Posts: 27,365
    edited April 2014
    Face wrote: »
    you noticed the parts express BP also. Man all that cash outlay and cheap's out on the post...Well all I have to say is they are either VERY GOOD or he ran out of money:lol: I've used them I do think they are very nice BUT come on man
  • embrown057
    embrown057 Posts: 46
    edited April 2014
    That's about the best presentation of the Duelund Products I've seen. Too bad there are not a lot of 1%'ers out there that can afford such extravagant parts. Thankfully Jeff (SoniCraft) is still turning out a great product that's affordable for most, if not all. I can see using there (Duelund) resistors in the future now that the supply of the "old mills" resistors are drying up. I've measured and forced myself to try the "Made In Mexico" Mills and they are very disappointing. Sure would be nice to hear that Duelund speaker set-up and man what a gorges speaker. I only know one person on this planet that could do that fine of woodwork (drumiv).
    edited April 2014
    Super high end, no replacement for excellent workmanship. Those crossovers would fit in well with those dude's from that Pakistan audio company. Those caps are pretty effin' cool.
  • drumminman
    drumminman Posts: 3,396
    edited April 2014
    Thanks for posting that Jesse. Gives me a new target to aim for. Wonder how much the inductors and caps cost? I'm guessing as much as a nice used car.
  • thsmith
    thsmith Posts: 6,082
    edited April 2014
    You would think he could afford a work bench or something other than sitting on the floor.
    Nice products though.
  • drumminman
    edited April 2014
    ZLTFUL wrote: »
    The cost is in the article. $12,402.18 in inductors, capacitors and resistors.
    :eek:
    :redface: Just looked at a few of the pics, thanks for that.
    F1nut Posts: 52,020
    edited April 2014
    Ok, my take. Yeah, those caps are cool and deserve to be shown off, but I don't like the wood support he used, not elegant enough. I would build a wooden display case type enclosure with thick clear Lexan windows on the sides and top. The top would be on hinges to allow access. The case would still be low to the ground, but supported by large custom turned brass spikes to match the brass on the speakers. I would have all the wiring going under a large black FR4 board (unclad PCB) supported on isloation devices. He seems to think that the only vibrations will come through the floor when in fact most will be in the air. My idea addresses both and would be a helluva lot classier. Forget those copper connectors, bare copper oxidzes. All connections would be soldered with Cardas. He goes on about how the wires do not go thru the binding posts. So what, the wires are still in contact with them. Get some Cardas or WBT posts and do it right.
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited April 2014
    ^^^^I'm glad that I'm not the only one that thought his design had a few flaws. I understand his want to showcase his investment, but I thought the connections should be hidden. Personally, I wouldn't buy $4k worth of cables that didn't have any better aesthetics than something that resembles white zip cord too, and I know that it is just cable dressing, but shouldn't that be included at that cost? I don't want my high end car in primer.
    F1nut Posts: 52,020
    edited April 2014
    Agreed, that boy needs some MIT's. :cheesygrin:
    nooshinjohn Posts: 26,003
    edited April 2014
    His workmanship on that board make me think of placing a golden doorknob on an outhouse. If he can afford 12k for the caps, why not spend another grand to showcase them...
  • Dennis Gardner
    edited April 2014
    With under board connections, he could have flipped most of the caps so that the leads went through the board and made a lot cleaner look. Dueland could have put stickers on either side by request if that is an issue.
    F1nut Posts: 52,020
    edited April 2014
    He didn't pay anywhere close to list, if he paid for them at all.
    Exactly. You can picture how cool that would look too.
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited April 2014
    This is exactly the kind of project I look forward to doing in the future, when I'm more dedicated to audio.
  • headrott
    headrott Posts: 5,496
    edited April 2014
    While I have yet to hear the Duelund Cast capacitors, a couple audio buddies have used them in their tube DAC's (similar to mine). They previously had V-cap (teflon) 2.2uF caps, Mundorf Silver, Gold, Oil 2.2uF prior to switching out both of the other caps for the Duelund Cast Copper PIO caps (the same as used in these crossovers).
    He stated that the difference in audio was absolutely breathtaking. The Duelund Cast Copper PIO caps left both the V-cap (teflon) and Mundorf Silver/Gold/Oil caps in a shameful state. Here is a picture of his "work in progress" for his DAC. Those 2.2uF Duelund Cast copper PIO caps are HUGE!!
  • bikerboy
    bikerboy Posts: 1,235
    edited April 2014
    No wait a minute, they forgot something.
    Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
    Bottlehead Eros
    CD: DIY Shigaclone
    F1nut Posts: 52,020
    edited April 2014
    For as long as you've been MIA I thought you would have this done by now. :wink:
  • Dennis Gardner
    edited April 2014
    I waiting until someone designs boutique vacuum tubes so that 12AX7s are the size of 55 gallon drums and 2A3s are water tank sized......
  • DarqueKnight
    edited April 2014
    Yeah, well, I'm doing a lot more listening these days and a lot less tweaking. :smile:
  • Face
    Face Posts: 14,340
    edited April 2014
    FYI, those caps are 20% off this month at PartsConnexion.
    treitz3 Posts: 20,132
    edited April 2014
    kevintomb wrote: »
    Wow, my projects, look like nothing compared to that!
    The crossover project we are working on will definitely be on par, perhaps a notch or two above depending on your tastes. It will definitely look better, that I can say with complete certainty. Nice job and definitely nice components on this build. Those Duelund components are no joke. Thanks for posting this, Jesse. Pretty cool stuff.
  • drumminman
    edited April 2014
    With the 20% discount it would cost $4784 to recap only the tweeter section in my 2.3TL's.
  • DarqueKnight
    edited April 2014
    With the 20% discount it would only cost $16,274.30 to recap my 1.2TLs. Then I would have to spend additional money on wiring and external enclosures.
  • headrott
    edited April 2014
    So, you guys are saying you are doing it?! Can't wait for the reviews! :smile:
  • Moose68Bash
    Moose68Bash Posts: 3,843
    edited April 2014
    Cheap at half the price! :-)
    DK, how much of a sonic quality upgrade would you expect from this extreme mod? Do you think it would make the 1.2TLs compete with first-rate contemporary speakers (which I think they already do!)?
