compliance problem? mw6511
DracoAmericanus
DracoAmericanus Posts: 112
edited April 2014 in Vintage Speakers
I was having a problem with one driver mechanically bottoming out in my sda srs 2.3 system, I swapped it out for another MW 6511 that had a broken magnet assembly that i was able to recenter and glue and the early bottoming out problem went away.
Has any one else experienced this problem? is the compliance from the spider and/or surround weakened from age or is there something that i may be missing? any ideas if it can be repaired?
There is no cure....
Luxman M117, SDA SRS 2.3, rear monitor 10, back rear bose 4.2, valodyne sub and 2 Onkyo m-504 amps Onkyo TX-NR709
8mm, 7.62x39mm
Post edited by DracoAmericanus on
