Quick way to break-in the capacitors
Aroundthesuond
Hello everyone,
as mentioned in another thread I open a discussion concerning the break-in of the capacitors.
What are for you the fastest and most effective methods?
maybe you would also like photos
thanks to all
thanks to all
Play the gear.
^^^^Best way I know of^^^^
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
Do you need to play it non stop, or can you start & stop at will?
What about new speakers or speakers that have been stored for a long time? Do these also need to be burnt in?- L200 Legends (Black Oak)
- SDA 2B (1989, Oak Tops, 194s, Spikes)
- Monitor 7B (1982 Peerless, Sonicaps, Mills, Binding Posts)
- (2) SVS SB12-NSD (Flat Black)
- SVS SB 3000 (Gloss Black)
- CSi A6 Center (Cherry)
- Pioneer SC-1222K (7.1 AVR)
- Marantz MM 7055 (5 Ch Amp)
- Pioneer PD-D6 SACD Player
- Marantz NR1403 (5.2 AVR)
- Sony UBP-X800M2 (4k Blu-ray)
- Sony UBP-X1100ES (4K Blu-ray)
- Adcom GFA 555 Amp
- Monitor 5 (194s, Side Surrounds)
- Monitor 5Jr+ (194s) {Storage}
- LG OLED65CXPUA (4K OLED TV)
- LG 55UN7300PUF (4K HD TV)
- RT35i (Cherry)
- (2 Pair) RT25i (Cherry)
- CS400 (Center)
- CS350 (Center)
- F/Xi A4 (Rear Surrounds)
- RT25 (Rear Surrounds) {Storage}
- Audioquest Interconnects
- Blu-Jean Speaker Cables & Interconnects
" But boy do I remember the strain of her refrain " LG -
i put them in my smoker, round 225F, for 8 hours. Applewood makes them sound sweeter, hickory more detailed.Polk Lsi9
N.E.W. A-20 class A 20W
Keces DA-131 mk.II
Paradigm DSP-3100 v.2 -
The only capacitors that might need a break-in are large old electrolytic's that have been in storage for years.
I listen to music as I normally would as mentioned above, and play pink noise at a low volume at night/when I'm gone.
Don't worry about it, just use equipment as you normally would.If you can't hear a difference, don't waste your money.
I believe that we are talking about two different situations.While I don't doubt your knowledge/credentials, our resident Ph.D. seems to believe otherwise. And has the scope shots to back it up.
Just do a search on:
Reforming Electrolytic Capacitors -
There were no links to other threads.
All of my above posts only refer to old Electrolytic Capacitors. -
OP I think you spelled your name wrong....shouldn't it be Aroundthesound...?Marantz 1152 DC- Denon DP 1200, Soundsmith Carmen MKII- ADS L980 - Blue Jeans IC's
About three years ago, Doug Self wrote an article on film cap warm-up distortion.
http://www.linearaudio.net/index.php?option=com_content&view=category&layout=blog&id=41&Itemid=73&limitstart=5 -
I believe that article was concerning polyester film caps, not polypropylene.film.
Apples and oranges are all fruit but not the same either. It never seems to end the "how to break in film caps" or Lytic's. This always turns out to be a debate as to "there must be a better way". What better way but to just use the gear as you would. For the past 35 years I have heard this same thing and no one has come up with a sure fire way to do this. Sure you can use your "cable burner" or other more complex methods. The only way your going to get that passive to "burn-in" and form is to run the complex signal through it over a period of time. Now I'm not trying to be the barer of bad new here but it is what it is and if anyone can come forth with a real solution here I would be the first to congratulate them.
Amongst the regulars of THIS forum, there is no debate... nobody ever says anything other than play the gear.
It's just that the question keeps getting asked.Polk Lsi9
Keces DA-131 mk.II
11TSteve:mabey there should be a warning on all forums "beware of false hope for early cap break-in". I see you have a B&K 200.2. Very nice amp and as rare as my DFA-1000/PM-95. I have had the privilege to work on one of them, I was extremely impressed with that unit. Very clean and can drive a very low impendence loan.
my post is on PP Caps
Polypropylene capacitors were in the article's third paragraph and it's very last sentence.embrown057 wrote: »I believe that article was concerning polyester film caps, not polypropylene.film. -
I still think OP spelled his name wrong...Marantz 1152 DC- Denon DP 1200, Soundsmith Carmen MKII- ADS L980 - Blue Jeans IC's
ooops2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
my nick is aroundthesuond, what is the problem ???
Instead of arguingand respond to my question in a serious way, you do problems on my nick.
I do not understand -
Aroundthesuond wrote: »Hello everyone, as mentioned in another thread I open a discussion concerning the break-in of the capacitors.
Break-in how. Are the caps being broke in for some selection process, or just a generic any cap in any piece of gear break-in time?Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
I do not understand
It's spelled sound, not suond. -
ok, so what's the problem ?
i'm free to choice my nick or not ?
please answer to my question instead of nonsense questions.
thank you -
now I think it's PFB having a joke......Polk Lsi9
Keces DA-131 mk.II
I'll add my two cents here. It appears English (The Queens or American English) is not your native language. If it were, we'd be better able to help you. Many Senior Members, who are very knowledgeable, have answered your question several times.Aroundthesuond wrote: »ok, so what's the problem ?
thank youHome Theater/2 Channel:
dhsspeakerservice.com/ -
I believe were just having a problem with your broken English. No disrespect intended but it would be better to type out you responses on MS word then cut and past. We have a disability not understanding the "Queens English". Several very good suggestion's have been made to you regarding your dilemma with "singing caps" yet you still either ignore them or find them inadequate. Please be more specific as to what your expecting for help in this tread.
Wow, Westmassguy hit it on the head, just must type faster than me, sucks getting old.
Yeah it does. I got aches and pains were I never knew you could have aches and painsembrown057 wrote: »Wow, Westmassguy hit it on the head, just must type faster than me, sucks getting old.Home Theater/2 Channel:
