MM6501 Woofer Broken - disappointed
jasonz1c
jasonz1c Posts: 1
edited March 2014 in Troubleshooting
I have a MM6501 set for my car and I recently noticed that the right side woofer was not playing.
Today I took apart the door panel and looked at the connectors on the back of the woofer. All was okay however still no sound?
Then I put pressure (pushed) on the woofer cone and the sound started playing. What is wrong with the woofer?
I've only had the MM6501 set for 6 months so I am extremely disappointed that this has occurred!!!
Regards,
Jason
Post edited by jasonz1c on
    F1nut Posts: 52,144
    edited March 2014
    If you purchased the set from an authorized dealer, the woofer is covered under warranty. CALL Polk tomorrow and they will take very good care of you.
    As to what could be the problem....a broken wire, bad solder joint, funky voice coil, etc.
  • DracoAmericanus
    DracoAmericanus Posts: 112
    edited March 2014
    If it's not under warranty and know how to solder i have seen solder failures on the wires that go from the terminal block to the cone on many different brands of speakers, re-soldering some times fixes that, only do that if there is no warranty
    There is no cure....
    Luxman M117, SDA SRS 2.3, rear monitor 10, back rear bose 4.2, valodyne sub and 2 Onkyo m-504 amps Onkyo TX-NR709
    8mm, 7.62x39mm
    F1nut Posts: 52,144
    edited March 2014
    Where did he go?
