I know what I want; You guys know better!! Next upgrade...
Sweets10v8
So I've been into the HT thing for 5 months, trying to learn and read as much as I can. Last time I was 95% sure what I thought was my next best move! and I was overwhelmingly corrected. I followed everyone's suggestion to to upgrade my sub next, and wow it's made a big impact, thanks again.
I'm again pretty sure what I want to do with my $400 budget for my next upgrade for my 100% HT rig....
(Copy/pasting my sig for future references;)
My setup;
AVR: Onkyo 818
Sub: SVS 25-31 PCi
Fronts: RTi 8s
Center: CS2
Surrounds: FXi 30s
Rears: Monitor 50s
1. Add used Emotiva XPA-3 amp for my front soundstage, actual 200w/ch (what I'm 90% leaning towards)
2. Sell CS2, buy CSI5, and then (fill in blank)
3. Add 2nd SVS 25-31 sub
4. Sell SVS 25-31 PCi, buy SVS pb12 ultra/2
My setup;
AVR: Onkyo 818
Sub: SVS 25-31 PCi
Fronts: RTi 8s
Center: CS2
Surrounds: FXi 30s
Rears: Monitor 50s
Man cave:
120" screen
Epson 8350 projector
4 Tap Kegerator
Audio:
AVR: Onkyo 818
Sub: SVS 25-31 PCi
Fronts: RTi 8s
Center: CSi5
Surrounds: FXi 30s
Rears: Monitor 50s
120" screen
4 Tap Kegerator
Audio:
AVR: Onkyo 818
Sub: SVS 25-31 PCi
Fronts: RTi 8s
Center: CSi5
Surrounds: FXi 30s
Rears: Monitor 50s
Post edited by Sweets10v8 on
Agreed, get the center and think about a Parasound amp--you have to be careful with Rtis as they are fairly bright so you need to consider what amps would warm that up some.
I have some Rti-A3s, a Csi-3 and older Polk sub that I run in a 3.1 in my basement room (probably move the Rti-4s from the bedroom down there eventually for 5.1). I've never been satisfied with the A-3s in the stereo mode...too bright, a little thin and bass shy as well, so I'm considering throwing a NAD on them and see what that does?
Oh Yea a large center and a clean amp.... OMG Nice!
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
See, I have no idea what sonic signature is...haha. I'm not used to asking and starting threads in forums, thanks for helping me out while I learn.Csi5 would be tops on my list. I'd recommend looking elsewhere for an amp based on the sonic signature of both Emotiva and the rti series.
How much are these warmer/ cleaner amps? I'll start looking up parasound, who else should I consider?Man cave:
120" screen
4 Tap Kegerator
Audio:
AVR: Onkyo 818
Sub: SVS 25-31 PCi
Fronts: RTi 8s
Center: CSi5
Surrounds: FXi 30s
Rears: Monitor 50s -
Parasound, nad, rotel are all amps that lean towards the warmer end of the spectrum. Your RTis are pretty bright, so amps like emotiva or adcom (although many would say overall a vintage adcom is a better choice) are not good to pair with Rti. With Rti8s you could get a Parasound HCA 1000 or 1200 and be fine...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
I also suggest getting the CSi5 Center channel. As far as adding an amp, I would sell the Onkyo 818 receiver and get into a higher end Pioneer Elite SC model. This way you would warm up your overall sound and add more power in the D3 amps. If you go used with an Elite SC model, the older models use Bang & Olufsen Amps which are still very good. They are also a Digital amp which uses less energy and provide more power. They also run much cooler then the standard A-B Designs of years past.
For your system if you go new I suggest eh SC-75. If you go used , I'd look at the SC-65, SC-55. With your budget and the sale of your Onkyo and CS2, I think you can score a nice upgrade here.
As far as running 2 subs? Yeah I find a better smoother in room response when using 2 subs over 1. 1 sub can be difficult to get right to satisfy multiple seating locations. With 2 subs you can really cover a room well. Running 2 subs IMO isn't for more volume or sheer impact, it's for better coverage. I strongly suggest using 2 of the same exact subs so one doesn't outperform the other. I have tried 2 different subs in setups and found that running the exact subs always works better.Dan
I WOULDN'T do 3 or 4. The rest of your system has alot of catching up to do before your SVS's need tweaking.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Center first, then an amp. You're a looong way away from upgrading that great subs.Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
So with my $400 budgeted, looks like its a CSi5, sell CS2. Looks like CSi5s are going for $150 to $200ish right now used.
Then save and research an amp......Man cave:
120" screen
4 Tap Kegerator
Audio:
AVR: Onkyo 818
Sub: SVS 25-31 PCi
Fronts: RTi 8s
Center: CSi5
Surrounds: FXi 30s
CSi5. Then the matching SVS.
Two Channel Setup:
Speakers: Wharfedale Opus 2-3
Integrated Amp: Krell S-300i
DAC: Arcam irDac
Source: iMac
Remote Control: iPad Mini
3.2 Home Theater Setup:
Fronts: Klipsch RP-160M
Center: Klipsch RP-160M
Subwoofer: SVS PB12NSD (X 2)
AVR: Yamaha Aventage RX-A2030
Blu Ray: Sony BDP-S790
TV Source: DirecTV Genie -
Adding a decent amp, am I going to notice a decent difference with my setup? I'm slightly worried I'm going to spend $400+ on an amp and not get a noticeable change, as I've never heard back to back non amped to amped speakers. I like to watch my movies at 70-75 volume setting on my AVR. From what I read I'd benefit in clarity, help keep my speakers and AVR alive longer as well.
My $350 sub BLEW me away, the RTi8 and FXis were noticeable too (part of that also may be moving Monitor 50s to rear and going to 7.1). That's why I'm wondering....
Found a ROTEL RMB-1095 for $525, but I've read they hum or buzz, and it's more than I have to spend nowMan cave:
120" screen
4 Tap Kegerator
Audio:
AVR: Onkyo 818
Sub: SVS 25-31 PCi
Fronts: RTi 8s
Center: CSi5
Surrounds: FXi 30s
There's a couple of things going on here. First off, I'm in the camp of "upgrade the center"
You'll be able to complete your front stage from a timbre mismatch to seamless.
Second, I think by your posts, you're looking for some votes on the amp because, that's what you really want.
Here's my take, you can ask for help or advice, but it's not steering you in the direction you want to go, then let go of everything and follow your gut.
Let's take a look at the amp, will it benefit your set up?? Sure! Since you have a sub, your speakers should be set to small so there's not a lot of power requirement there, but if you like to crank it, then the extra power will come in handy.
If you like 2ch, and I hear those i8's are awesome for that, then having some power behind them for 2ch would also be of some benefit, esp if you don't use your sub.
So, time to stand on it son, hit the gas and go for the win!!Source: BRP Panasonic UB9000, CDP Emotiva ERC3 - Display: LG OLED EVO 83 C3 - Pre/Pro: Marantz 8802A - Amplification: Emotiva XPA-DR3, XPA-2 x 2, XPA-6, Speakers, Mains/2ch-Focal Kanta No2's, C-LSiM706, S-702F/X, RS-RTiA9's, WS-RTiA9's, FH-RTiA3's, Subs - Epik Empire x 2
Cables: AudioQuest McKenzie XLR's/CDP/Amp, Carbon 48/BRP, Forest 48/Display, 2 channel speaker cable: Furutech FS Alpha 36 12AWG PCOCC Single Crystal (Douglas Connection)
When I was young, I was Superman but now that old age has gotten the best of me I'm only Batman -
I'm past csi5, I'm doing that for sure first.. Just finding one is what I'm doing now, while trying to educate myself on amps.
Seems the overwhelming idea after that is an amp, it's just not cut and dry to me yet with all the requirements and all the information to take in. I'd love to be able to try out an amp to get a feel for what's next.
So can you bi-amp the RTI 8s with 200w per post or is that total the speaker can handle?Man cave:
120" screen
4 Tap Kegerator
Audio:
AVR: Onkyo 818
Sub: SVS 25-31 PCi
Fronts: RTi 8s
Center: CSi5
Surrounds: FXi 30s
Bi-amping with your AVR is a gimmick and will not give you any more power, as the amps draw on the same power supply within the AVR. To benefit from Biamping you need two separate amps.
Your 818 is a very good receiver, no reason to upgrade that right away. I agree Csi5, then power amp, a stereo amp would take a large load off of your Onkyo which would in turn allow the center and surrounds sound much better. You can certainly find a decent used stereo amp within your budget. However, a multichannel would be "best" for home theater, either would provide a noticeable improvement.Oh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant -
Forget bi-amping.Political Correctness'.........defined
President of Club Polk -
Bi amp with the pre amp channels, not receiver... I know that the receiver won't do anything.
Although my heart really wants the SVS PB12 ultra/2. I've seen it, it's a 190lb tank! But I'm listening to everyone else's expertise....Man cave:
120" screen
4 Tap Kegerator
Audio:
AVR: Onkyo 818
Sub: SVS 25-31 PCi
Fronts: RTi 8s
Center: CSi5
Surrounds: FXi 30s
Do some research on what bi-amping really is because it's not what you think.Political Correctness'.........defined
Sweets10v8 wrote: »So can you bi-amp the RTI 8s with 200w per post or is that total the speaker can handle?
Don't pay attention to those recommended wattage numbers. All you need is clean high current from a single channel of amplification. Bi-amping is another animal.....and has nothing to do with a receiver.HT SYSTEM-
lsi 9's -
Bi amping was a simple question if I used two channels on an amp, not avr. Say I get 5 channel, run two to each of the fronts, and one to the center, let avr power the surrounds... But never mind, it's thrown off the thread, thought I could get a simple yes or no. I'm not worried about it, was just trying to learn if that's how it works....Man cave:
120" screen
4 Tap Kegerator
Audio:
AVR: Onkyo 818
Sub: SVS 25-31 PCi
Fronts: RTi 8s
Center: CSi5
Surrounds: FXi 30s
The secondary benefit from amp, after the CSI5, is the ability to properly power 4 ohm speakers down the road if I ever decide to upgrade to LSi series, or whatever I come up with.Man cave:
120" screen
4 Tap Kegerator
Audio:
AVR: Onkyo 818
Sub: SVS 25-31 PCi
Fronts: RTi 8s
Center: CSi5
Surrounds: FXi 30s
actually can't upgrade the 818, promised my wife I would keep it for a few years. It's the only thing I've bought new.jeremymarcinko wrote: »Your 818 is a very good receiver, no reason to upgrade that right away. I agree Csi5, then power amp, a stereo amp would take a large load off of your Onkyo which would in turn allow the center and surrounds sound much better. You can certainly find a decent used stereo amp within your budget. However, a multichannel would be "best" for home theater, either would provide a noticeable improvement.
thanks, appreciate it. So what do you think of the rotel rmb-1025 I saw for $525? Assuming my setup except with csi5?Don't upgrade to LSi's for a HT build. Deal with an amp AFTER you upgrade to new speakers - your speaker SHOULD influence your amp choice. For example, my monoblocks don't work on many speakers, but sound superb on my 6311's. I wouldn't have bought them if I didn't know before hand that my speakers could do well off low-powered tube amps.
Edit: also see a rotel rmb-985 for $350Man cave:
120" screen
4 Tap Kegerator
Audio:
AVR: Onkyo 818
Sub: SVS 25-31 PCi
Fronts: RTi 8s
Center: CSi5
Surrounds: FXi 30s
Sweets10v8 wrote: »Bi amping was a simple question if I used two channels on an amp, not avr. Say I get 5 channel, run two to each of the fronts, and one to the center, let avr power the surrounds... But never mind, it's thrown off the thread, thought I could get a simple yes or no. I'm not worried about it, was just trying to learn if that's how it works....
Simple answer with using 2 amp channels to one speaker....yes you can. Will it make a market improvement ? Yes and no...depends on the amp....and the speakers. Some speaker designs are inherently power hungry while others aren't as much. Also, the top portion of most speakers use very little power, 10-30 watts probably for most common name speakers. Why dedicate 200+ watts to a channel that won't use it ? See what I'm sayin' ?HT SYSTEM-
lsi 9's -
Ok thanks,
so by running one 200w signal to a single front speaker, just makes the 200w available to be used by whatever askes for it? (Within the entire system of components in that single speaker)?
As in, not feeding it 200w and forcing it to take it all the time, but just having it available to be used.Man cave:
120" screen
4 Tap Kegerator
Audio:
AVR: Onkyo 818
Sub: SVS 25-31 PCi
Fronts: RTi 8s
Center: CSi5
Surrounds: FXi 30s
Sweets10v8 wrote: »Ok thanks,
You got the first part right.....but not sure where your going on the second part. Lets say for example you use a 2 channel 200 watt amp, the amp does not put out the full rated power as soon as you turn it on. It's not automatically feeding 200 watts to your speakers. An amp stores power basically to use when the volume dial and speakers ask for more power....up to their limits anyway. Always better to have more power available than not enough.HT SYSTEM-
lsi 9's -
Gotcha.... Soon I may be able to even look at classified here, haha not quite to 100 yetMan cave:
120" screen
4 Tap Kegerator
Audio:
AVR: Onkyo 818
Sub: SVS 25-31 PCi
Fronts: RTi 8s
Center: CSi5
Surrounds: FXi 30s
Normally speakers with more drivers will need more current to stop and start those drivers. Certain designs, parts used, amount of bigger drivers will dictate how much power is necessary. Usually in most speakers the lower mids and bass drivers need the most current to sound their best and operate to their potential. Notice I said current and not watts, you want to look at amps that are higher current, usually stated as amperes peek to peek. Good solid state amps for bigger speakers with a lot of drivers have between 50-80 ampere's peek to peek. Also depends on how loud you like it too. The louder you like it, the more you turn up the volume dial, the more the speakers ask for power and the amp has to put out....if it's available. If not, you clip and send distortion into your speakers toasting a tweeter or crossover.
More so a simpler explanation to help you, really is more to it than that but put in simple terms. Now taking an amp channel and simply putting it on the top post of the speaker, which may use only 30 watts, what happens to those other 170 watts from that 200 watt amp ? It goes unused....poof....not available to the bottom portion that really sucks up the power needs.
Some speaker designs can and do benefit more so from amping up both sets of posts separately. IMHO...Polks aren't one of them as their current designs are pretty efficient. A high current, 200 watt+ per channel amp by any decent brand is more than enough to power most the speakers out there today using one set of posts on the speaker. Exceptions of course are out there, but you get what I mean.HT SYSTEM-
lsi 9's -
The more compilcated answer is it's still not really bi-amping. True bi-amping requires a completely separate amp for each speaker and the use of an active crossover.Political Correctness'.........defined
