Furman or Panamax or Whole Home Surge protection
EndersShadow
EndersShadow Posts: 17,707
edited April 2014 in Electronics
So I just snagged a APC H15 yesterday for my 2 channel system. 80% of my expensive gear in the house is now protected. But I still need a power conditioner for my bedroom system, which is fairly basic. It consists of a 32" LCD TV, Soundbar 1000, Motorola Router, Modem, Wireless transmitter (for downstairs Uverse box), Roku.
I was going to snag another APC unit, but here's the snag, I need it to be able to filter a Ethernet jack. So I was looking at either Furman or Panamax to see what models I should be looking for online, as well as a baseline for what they tend to go for (if you happen to know).
I am also not against getting a whole home surge protector, but dont know diddly about those as far as cost, what are good brands, etc.
So any help would be greatly appreciated.
Planning in advance here so I am more than ok with waiting for the "right" unit at the "right" price to come along.
Post edited by EndersShadow on
  • Polkie2009
    Polkie2009 Posts: 3,834
    edited March 2014
    I've noticed in many previous threads about surge protection, many have added SurgeX to the brands you've listed. I too, would like to explore the whole house protection option and costs.
    edited March 2014
    Polkie2009 wrote: »
    Yeah, but IIRC SurgeX doesn't allow for a Ethernet connection to be filtered. Otherwise while they are but ugly, they work good and since its the bedroom, I could hide it easier....
    If I have to give up the Ethernet filtered aspect then I may just look at Surge-X unit, though TBH there is a APC H15 on ebay for 100 that would work just fine and is hard to beat at that price.
    txcoastal1 Posts: 13,513
    edited March 2014
    For protection a whole house system is nice but in most cases cost prohibitive. Filtering is another issue in itself. A lot of the EMI/RF noise is produced in the home i.e. florescent lighting including the energy bulbs, the transformers in LED fixtures also create line noise.
    That is why I prefer a dedicated unit solely for each system
    edited March 2014
    txcoastal1 wrote: »
    Gotcha Ron. Thanks for the info, both in the post and also via your email to me. I will stick with the dedicated unit per system, and look for some nice used Panamax units on ebay or here as they come up.
  • RamZet
    RamZet Posts: 792
    edited March 2014
    We installed a lot of Furman product. Now we are removing a lot of dead Furman product.
    We replaced Furman with Panamax. I use a Furman F1000-UPS in my personal rack for network gear and a Furman line conditioner for amps and stereo equipment.
    The Panamax stuff I have been installing for a few years now is very nice and just continues to get better with every change they make to a product line. When my Furman stuff dies it will get replaced with Panamax.
    If youre going to spend a lot of money on an item I would look at the 20 amp BlueBolt by Panamax. I think its 2K. 2150 with the remote power management card ( Enet card).
    http://www.panamax.com/Products/A-V-Components/M4320-PRO.php (20 amp)
    http://www.panamax.com/Products/A-V-Components/M4315-PRO.php (15 amp)
    B&W CM9Classé Sigma
  • recoveryone
    recoveryone Posts: 929
    edited April 2014
    Just picked up a used Panamax Max 500 for my 2ch, first impression is that I did notice a deeper blackness and a bit more detail in the midrange and much more detail at lower volume. Hope to pick up a 5300MX for the HT soon.
    gudnoyez Posts: 8,166
    edited April 2014
    http://www.panamax.com/Products/A-V-Components/MR4300.php#tab_images
    I got one of these for the HT, I will get another one for 2 channel as I like this one a lot. Paid $279.00
  • voltz
    voltz Posts: 5,384
    edited April 2014
    got a M4300-pm from crutchfield for $199 but they don't seem to carry them anymore, but just saw a MR4300 on ebay for $199
  • mantis
    mantis Posts: 17,455
    edited April 2014
    APC or Panamax is the way to go for your needs.
    Dan
  • unc2701
    unc2701 Posts: 3,587
    edited April 2014
    I'm a big fan of surgex and they make panel boxes so you can keep them out of sight- move the existing line to the surgeX box, then run a short line to the panel (or put the surgeX box in an attic or crawlspace). You can get them with noise filtering, but as noted, no ethernet protection/ filtering. However, a surge is unlikely to get more than one device down a line: Let's say your xbox isn't protected, a surge might kill it and _maybe_ your switch (which is on a protected circuit), but definitely not anything else attached to the switch.
    I've had zero issues since I've been using them and they've got major advantages over MOV based products for surge protection (not so much on filtering).
    Backburner:Krell KAV-300i
  • kevhed72
    kevhed72 Posts: 5,146
    edited April 2014
    Audio Advisor has a couple of nice looking demo units from Furman right now.
  • recoveryone
    edited April 2014
    Here is my latest addition to my HT
    Panamax M5300-EX
