transformator for Polk Audio AM6500-A Surround Bar 6500BT in israel
burga
burga Posts: 3
edited March 2014 in Troubleshooting
Hi , im from israel and wanna order this item from amazon , please tell me would i need an Appropriate transformator or i can use the the included one ?
Thanks.
Post edited by burga on
  • rpf65
    rpf65 Posts: 2,127
    edited March 2014
    Your post is a little confusing. What exactly do you think would be the issue, in as non-technical terms as possible.
    txcoastal1 Posts: 13,306
    edited March 2014
    Is Israel 110VAC or 220VAC
    There is no mention of voltage on the website, will see if Ken can chime in and help
  • On3s&Z3r0s
    On3s&Z3r0s Posts: 1,013
    edited March 2014
    I think Israel is 220V / 50Hz. The manual (http://www.polkaudio.com/downloads/manual/SB6500BT_MN_digital.pdf) says the inputs for both the surround bar's power brick and the subwoofer are 100V - 240V, 50Hz - 60Hz, so you should be able to get away with just an adapter for the outlet, but if you've got time to wait for a reply it might be best to let someone from Polk customer service answer before making a purchase (Ken, mentioned above).
    edited March 2014
    Good job ON3 guess I loaded marketing brochure
  • burga
    burga Posts: 3
    edited March 2014
    thank you very much for a quick repply i guess ill wait for Ken to be 100% sure
  • [Deleted User]
    [Deleted User] Posts: 7,658
    edited March 2014
    Hello burga,
    I believe the system automatically operates with your local voltage, but let me check with Polk's CS department to be 100% sure.
    Regards, Ken
  • [Deleted User]
    edited March 2014
    Hello,
    Polk CS confirmed the power supply is automatically designed to operate with your voltage and frequency. Depending upon where the SB is purchased you might need a different power cord to fit your country's AC outlet.
    Regards, Ken
  • burga
    burga Posts: 3
    edited March 2014
    Thanks Ken ,
    Regards
  • [Deleted User]
    edited March 2014
    You're welcome, glad to be of help. Take care, Ken
