Amp for SRS SDA 2
[Deleted User]
[Deleted User] Posts: 365
edited March 2014 in Vintage Speakers
Hello guys,
First post here on the Polk Forum. I just traded for a really clean pair of SDA 2s and need a bigger amp. Right now I have a Onkyo 80 watt receiver, which actually works better than I thought it would, but I know I need a lot more power.
I was going to order the Emotive XPA-2 and use it with a Onkyo Integra 3060R preamp. What do you think? The room is 20x40.
Should I expect a big difference?
Thanks for any help
Tony
  • zingo
    zingo Posts: 11,258
    edited March 2014
    That will be a big upgrade for those speakers!
  • Polkie2009
    Polkie2009 Posts: 3,834
    edited March 2014
    Congrats on the speaks Tony and welcome to the forum. I would take a strong look at a good used amp like a Parasound HCA-1200 II or 1500 . What is you're budget for a power amp? There are so many good choices for you to look at besides the XPA-2 imho.
  • [Deleted User]
    edited March 2014
    Polkie2009 wrote: »
    I'd like to keep it at around 1K.
  • Polkie2009
    edited March 2014
    That's awesome Tony, you're going to be able to find some excellent power amps at that kind of coin sir!
  • [Deleted User]
    edited March 2014
    How about an Adcom GFA-555SE ?
  • chandler9a
    chandler9a Posts: 878
    edited March 2014
    The Adcom would be fine, I ran one for years. I too just acquired some SRS 2's and run them with a B&K 200.2 amp and love it. Either of those choices should leave room in the budget for new RDO-194 tweets from Polk.
  • [Deleted User]
    edited March 2014
    chandler9a wrote: »
    Should the tweeter upgrade be the first in the mod chain?
  • chandler9a
    edited March 2014
    If you are talking about speakers only, yes, IMO. But you may just want to keep them fully stock for a while and buy an amp to run them and listen to them like they are.
    You will love the differences you hear as you go.
    Welcome aboard
  • avguytx
    avguytx Posts: 1,628
    edited March 2014
    Are we talking SDA SRS 2's or SDA 2's?
    Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
  • Schurkey
    Schurkey Posts: 2,122
    edited March 2014
    TForan wrote: »
    TForan wrote: »
    With that budget, you could buy a REAL amp, there's no need to handicap yourself by buying Communist Chinese crap.
    TForan wrote: »
    If it were me, I'd re-cap the crossover BEFORE installing fresh tweeters. This presumes that all four tweeters actually work, all eight drivers actually work, and the passives aren't destroyed. All of this is likely, but not guaranteed. Whatever you do inside the cabinet, you also need to assure that the polyfill has been pulled up--it's probably sagged after all these years, and the cabinet needs to be reasonably well-sealed.
    If these are blade/blade SRS 2s, you'll want to decide whether to upgrade to the "standard replacement" RD0-194 tweeters, or to change a cap in the crossover and go with the '198s.
  • [Deleted User]
    edited March 2014
    Schurkey wrote: »
    Everything works as far as I can tell. I'm getting a Yamaha P2002M today. Thanks,again.
  • Schurkey
    edited March 2014
    TForan wrote: »
    PC2002M??? Very scary. I can't find a 4-ohm rating for that amp. Found several sources that all say the same thing: 240 w/c/8, 700 w/c/8 mono. Nowhere do they discuss 4-ohm operation. I tried downloading operator's manuals, but without success.
    First Guess: Current-limited.
    The blade/blade SRS 2 is a "4-ohm" speaker; the pin/blade SRS 2 is 6-ohm. Either way, a current-limited amp is not a good choice. You start replacing inductors, and things get even worse.
  • FTGV
    FTGV Posts: 3,650
    edited March 2014
    Looking at the manual for the PC2002 ,fig.3 is a graph that shows output vs load.It obviously has no problem with 4 ohm loads.The beefy looking output stage and power supply would seem to support that.Why they don't rate it for 4 ohm use?My guess is some sort of FTC rating thing of the day?
  • [Deleted User]
    edited March 2014
    Well, I got it all hooked up and to be honest, I'm less then impressed. The highs are strident, the bass is there but kind of muddy. Same with the mid- range, especially on vocals. I tried it with different electronics and basically the same results. These are the Blade/ blade SRSs that have a few updates( Hurricane nuts, and banana plugs for the SDA connection.
    I do enjoy the big soundstage and was wondering how much real difference the crossover and tweeter mod really makes or maybe they just aren't for me.
    Electronics are a Yamaha PC2002M, Onkyo 3060r preamp, Schitt's Modi and a Yamaha PX-2 turntable.
    Thanks again for any help.
  • zingo
    zingo Posts: 11,258
    edited March 2014
    Could be crossovers and the stock SL2000 tweeter.... Placement is also a big deal with these speakers, especially if you are getting muddy bass. I know the bass is more muddy on my SRS 2s than with a power subwoofer, but try moving them away from the walls/corners, and possibly adding spikes.
  • [Deleted User]
    edited March 2014
    I think it might be the preamp. I moved to a wall that has 20 ft clear on both sides and that helped a lot but still I occasionally heard a scratchy distortion. My stereo/ mono switch has always been noisy, so I blasted it with deoxit and cleared it up. Can a dirty switch like that cause distortion? Anyway, I'm going to keep them and get them sounding right. Maybe it's also time for a tube preamp!
    pitdogg2 Posts: 27,207
    edited March 2014
    Do not toe them in if you have. I had to move mine in and out from the wall to get good bass. Mine sit 7" off my wall.
  • chandler9a
    edited March 2014
    Just added spikes to mine, works/sounds great.
  • TennMan
    TennMan Posts: 1,266
    edited March 2014
    Don't overlook the simple things. Do the battery test to make sure all the drivers are in phase. - Disconnect the IC cable. Then momentarily connect a 1.5 volt flashlight battery to the plus and minus terminals on the back of the speakers while observing the drivers. All the drivers should move out at the same time.
    Also check carefully to make sure the polarity of the speaker wires is correct all the way back to the amp. SDAs sound like crap when they are out of phase.
  • chandler9a
    edited March 2014
    TennMan wrote: »
    Not a bad idea, I've found this to be the problem more times than I would like to admit.
  • ALSATIAN in USA
    ALSATIAN in USA Posts: 127
    edited March 2014
    I have the same problem with the SRS (but good bass). The tweeter are super loud, the sda drivers sound "hear percing" with some passages, i'am sure it's because I need to upgrade my X-over but won't to spend $800 on that! I just use 2 differents EV (P series) and tame the tweeter with minus 3db with the volume knob of one amp.
    edited March 2014
    That EV amp is probably your reason for ear piercing highs.
    edited March 2014
    BTW OP.....your Yamaha is pretty cool looking, but it's got no balls ....not enough current for anything other than an 8 ohm speaker.
  • ALSATIAN in USA
    edited March 2014
    I had this problem sinse I played loudy one afternoon for 3-4hours with a CARVER PM700 (my woofers was at 3-4mm X-mass), then I pluged a CARVER PM1400, a Kenwood KM209, a NAD 2400 THX, all make my SDA ear piercing with no bass...Then with my EV P1200 for tweeter and my EV P1202 for woofers boost my bass (the EV (old "gunship gray" version) are wonderfull).
  • ALSATIAN in USA
    edited March 2014
    Also, the YAMAHA PC2002M are superbe amp and try to find the "Rolls-Royce", the PC5002M (my dream) http://www.thevintageknob.org/yamaha-101M.html
  • Schurkey
    edited March 2014
    TForan wrote: »
    My 1Bs are very similar to the blade/blade SRS 2. My complaint with them is recessed treble. If you think they're strident, either you have something else going on upstream, or there's something genuinely wrong with the speakers--or you're sensitive to the 12K peak of the SL2000 tweeters. Muddy bass is similarly NOT a characteristic I'd associate with 1B/SRS 2 speakers.
    TForan wrote: »
    How much difference the crossover and tweeter mods make partially depends on what's wrong with them now. If you've got failed tweeters or failed crossover components, "upgrades" which repair existing problems can make a world of difference.
    I'm not sure why you think crosssover upgrades need to cost $800.
  • [Deleted User]
    edited March 2014
    tonyb wrote: »
    I was playing it at rather extreme volume last night and the amp was hardly working. Cool to the touch and it didn't trigger any protection circuits. Now, with my 100 watt receiver, I could definitely hear the strain. Not saying you're incorrect, just passing along my experience.
  • [Deleted User]
    edited March 2014
    Distortion turned out to be the equalizer and input in Itunes was jacked up too far.
