Replacement tweeter wiring question
cjcinkc
cjcinkc Posts: 10
edited February 2004 in Troubleshooting
Does it matter which side of a replacement tweeter gets the black/white wire? Unlike the SL2000 that died, the replacement doesn't have a discernable "up" or "down". I wired it up both ways and couldn't tell a difference in phasing while running the THX audio test, so I soldered it in. Now I'm having second thoughts.
Any suggestions?:confused:
My little system:
Rcvr/Amp: Yamaha RX-V2400 (6.1)
Front: POLK Monitor 5A (27 years old and still pumping!)
Rear: POLK FXi3
Sub: POLK PSW150
Vid: Samsung Tantus 32" HDTV
Post edited by cjcinkc on
    F1nut Posts: 52,008
    Is there not a + mark in the plastic on the back surface?
  • warlocks1
    warlocks1 Posts: 1,284
    I am not sure about the tweeters, but on the replacement drivers I received from Polk, there was a red dot by the positive connector.
  • cjcinkc
    cjcinkc Posts: 10
    No marks of any kind on the plastic or the tweeter. I'm stumped.
    My little system:
    Rear: POLK FXi3
    Sub: POLK PSW150
    VR3 Posts: 29,550
    Pics?
  • HBombToo
    HBombToo Posts: 5,256
    Russ knows a trick but i can't find it.
    1/4twin
    ***WAREMTAE***
    VR3 Posts: 29,550
    That only works on a woofer Henry.
    You plug a woofer up to a battery. Positive or negative, and if it is right it will move in then out, and if wrong out then in (I think).
    A tweeter isnt that obvious, know what I mean? lol
    Best way to do it, is wire it to where it sounds best. Best way to do this is put in a cd with a killer soundstage and listen, if its out of phased, u will have a SMALL soundstage (I would think)
    But then again, I'm just talking out of my butt......I dont know........dont mind me, i need to go to bed
    insomniac sid!
  • cjcinkc
    cjcinkc Posts: 10
    If I didn't mention previously, this is the BD0194-A replacement tweeter. Unfortunately, no instructions came with...
    I'm familiar with the woofer trick using a battery, but that's no good here. I think I mentioned using the THX Audio Phasing test, but I couldn't tell a difference when the dvd switched between playing in & out of phase no matter which way I wired it.
    Can a Polk engineer confirm: does it matter???
    My little system:
    Rear: POLK FXi3
    Sub: POLK PSW150
    F1nut Posts: 52,008
    I have one of the new replacement tweeters for the SL3000, it has one terminal colored red, no other marks or paper label like the originals did. Are you sure one of the terminals wasn't colored red before you soldered the wires to them?
    Anyway, I suggest you call Ken Swauger at Polk customer service. I am 100% positive he will have an answer for you.
  • cjcinkc
    cjcinkc Posts: 10
    F1 -
    I didn't notice a red terminal -- but then I'm color-blind(!). I'm have to ask my wife to take a look and tell me if I missed it.
    I'll definitely call Ken next week if I don't see a red terminal. Next dumb question -- which lead goes to red: white or black? I could pull the driver out to follow the wiring from the crossover, but don't really want to do that.
    Thanks again -
    Chris
    My little system:
    Rear: POLK FXi3
    Sub: POLK PSW150
    F1nut Posts: 52,008
    Chris,
    White is the positive lead and goes to the red terminal. Let us know what your wife finds or what Ken has to say.
    F1
  • cjcinkc
    cjcinkc Posts: 10
    For the BD0194-A tweeter:
    Looking at the back of the tweeter ("magnet side"), there is supposed to be a small red dot denoting the negative terminal (mine doesn't have the dot). The other way to tell is by holding the tweeter with the part number facing up, the right terminal is postive, left terminal is negative. On some models, one terminal is larger than the other. The smaller terminal is positive.
    Also, slight correction to F1's previous response -- the black wire is positive; white is negative.
    Ken suggested putting a 2.5kHz tone through to the speakers to verify phasing. Unfortunately I don't have a signal generator, so I'll have to find a solo flute or violin phrase that I can put in repeat mode.
    Mystery solved. Thanks everyone -- this has been frustating, yet educational.
    Chris
    My little system:
    Rear: POLK FXi3
    Sub: POLK PSW150
  • dorokusai
    dorokusai Posts: 25,576
    Yea the white wire/black wire issue is also the same condition that applied to my Monitor 10B's....it was the reverse of what would be "normal".
    The only way to really be sure is to trace it to the crossover.
  • HBombToo
    I ran into the same problem while rebuilding my 8T's... during my 55 to 55i conversion I found that the connectors are unique between the plus minus. Polk probably did that in an effort to decrease the number of calls to Ken:p
    HBomb
    ***WAREMTAE***
    F1nut Posts: 52,008
    Well, this is all very interesting.
    On my SDA 2.3TL's the black wire goes to the red dot on the mids. The tweeters have white wires running to both terminals, one has a red piece of tape on it and goes to the small terminal. This is all very confusing, everything sounds right. I think I'll trace the wires from the crossover just to be sure.
