How I REMOVE HOT GLUE **** Hint Freeze Spray ****
Tronman
Tronman Posts: 72
edited February 2014 in DIY, Mods & Tweaks
I have read alot of the forums here and always come across the HOT GLUE issue and how to remove it. The easiest way I have found is to take freeze spray or just take a can of duster spray and turn it upside down and spray the liquid on the HOT GLUE you would like to remove - make sure you get it really cold and while the liquid is still on the glue you can just pop it off with a screwdriver. The glue becomes so hard it looses it's stickiness and will just break off in chunks. You will notice as the liquid dissipates the glue will become soft again and you will need to apply more freeze spray.
I have read the Isopropyl alcohol method in some of the forums which obviously must work but takes longer. I hope this idea helps somebody if you are willing to give it a try - I have been using this method for years :-)
If you have good luck with it let me know.
Post edited by Tronman on
    VR3 Posts: 29,554
    isopropyl alcohol, pops right off :)
    F1nut Posts: 52,018
    VR3 wrote: »
    This.....works in seconds.
  • Moose68Bash
    Moose68Bash Posts: 3,843
    Hey, why didn't you guys clue me in on the isopropyl alcohol trip when I was modding my SRSs and 1Cs?
    Newbie initiation rite?
    Oh, the elbow grease I spent! :-)
  • zingo
    zingo Posts: 11,258
    You didn't look in the right place... :redface: I've always just scraped it off myself, so don't feel too bad.
    pitdogg2 Posts: 27,361
    silly me i just get a good grip on it with my pliers comes right off...
    That air duster also can be used to remove warts. Turn it upside down like he said spray into a Q-tip and apply...repeat.
  • Moose68Bash
    zingo wrote: »
    Cut, pry, scrape. Cut, pry, scrape. Cut some more, pry some more, scrape some more.
    Ad infinitum et ad nauseum!
    Hey, I just wonder, would grain neutral spirits (aka vodka) work as well! :-)
    Why waste good vodka!
    Hey, I just wonder, wood grain neutral spirits (aka vodka) work as well! :-)
    If your Vodka is made from "wood grain" it no wonder you can't see.....
  • Moose68Bash
    Oops! Corrected the typo -- "wood" should have been "would."
    I also think gin is "grain neutral spirit," not vodka.
    I'm really not much of drinker of distilled spirits -- generally only single malt.
    I was just rying to be humorous in the midst of our last dump of snow.
  • 11tsteve
    11tsteve Posts: 1,166
    super glad this thread happened when it did. It made recapping my 5JR's a breeze this morning. Literally seconds....Thanks Trey and Jesse!
    Polk Lsi9
    N.E.W. A-20 class A 20W
    Keces DA-131 mk.II
    Paradigm DSP-3100 v.2
  • gimpod
    gimpod Posts: 1,793
    VR3 wrote: »
    Ditto .... Hot Glue & How to remove it
    Google & search is your friend Searching Club Polk suggestions
  • Tronman
    Tronman Posts: 72
    Well I'll tell you what, looking at my SDA-1C's they were not stingy on the glue in some places WOW that is a lot of glue. :-) Got the drivers out tonight while listening to my SDA-2A's cranked up, sound really good with a Carver TFM-35, might have to bust out the big guns and use my Carver M1.5t or Hafler 9505 :-). Glad this thread has helped somebody
