Has anyone heard a better center than the 706?
Lan077
Lan077 Posts: 31
edited February 2014 in Speakers
I'm not really considering any matching factors here. Just as far as getting the vocals perfectly natural.
Post edited by Lan077 on
  • aboroth00
    aboroth00 Posts: 1,106
    Revel Ultima Center sounds good.
    2Ch Tube Audio Convert
  • falconcry72
    falconcry72 Posts: 3,580
    The 706 an excellent center channel speaker. Another awesome one is the Usher Audio 616-BE DMD. The Usher is grittier whereas the LSiM is smoother... I think it would come down to personal preference bectween the two.
    I think the best center channel speaker is 3rd of whatever your fronts are.
  • Lan077
    Lan077 Posts: 31
    ZLTFUL wrote: »
    Onix Rocket Bigfoot tops my personal list but then good luck finding one. The TOTL Paradigm monster center sounds pretty dang good too.
    Interesting, I saw a couple used ones (bigfoots) on ebay go for about $300 last year.
  • polkfarmboy
    polkfarmboy Posts: 5,703
    The Martin Logan stage center has got to be one of the best out there but will only go with other stats and when you sit up from the chair the "stage" collapses.
  • mantis
    mantis Posts: 17,563
    When you own speakers any brand , the matching center will always perform the best with them. I never once heard a mixed matched front end sound better with a different brand center channel.
    I don't even get this line of thinking. If the center channel of a given speaker package is not to your liking, you need a different line of speakers all together period.
    Dan
  • Lan077
    Lan077 Posts: 31
    mantis wrote: »
    From what I read no centers really match their fronts that closely. Mostly due to being a horizontal cabinet which result in uncorrectable off axis response differences. Having the same drivers with similar crossover points obviously help some, a little....
  • ken brydson
    ken brydson Posts: 9,024
    Lan077 wrote: »
    No complaints with mine.
  • Face
    Face Posts: 14,340
    Lan077 wrote: »
    If the tweeter and mid configuration are the same as the mains(tweeter over mid or vice versa), then it should match the other speakers well. It's when a tweeter is horizontally paired with the mid(s), lobing is an issue. More center channels should be designed in the same fashion as the 706C.
