Best cartrage for a Technics SL 1700 table
bobt
bobt Posts: 280
edited February 2014 in 2 Channel Audio
Not sure what I should put in there. a Grado seems to be fine, as I tend to like them, but I have not heard any in a long time.
I want to keep it like 150. Any better ideas on that?
Post edited by bobt on
  • TNHNDYMAN
    TNHNDYMAN Posts: 2,145
    Shure M97xe or Orotofon Red would be two good options. I've used both on my SL 1600 and prefer the Shure for less than perfect records.....
  • bobt
    bobt Posts: 280
    My wife just bought me a new Led Zep the song remains the same.....full on LP's heavy duty 180 grams at least. So I need to put in a new cartrage. A fairly good one...LOL I tried the Orotofon stuff before. Not cheap, back in the day. It was passable. did not float my boat really. The Grado or Shure may be better on the SL.
  • leftwinger57
    leftwinger57 Posts: 2,917
    I had a Shure Mk v I believe back in the day w/ my Dual. Now I use the older Grado GF-3 and just got a Grado Black for $30 1/2 price then anywhere eles. They have other Grados and more brands. Truth be told I have not installed it yet, my tt died just as I got the cart delivered. I got it from Statement Audio Tom Manley the guy who works w/ Terry Dewick the McIntosh specialist down in Knoxville.
    http://www.mcintoshaudio.com/
  • PolkieMan
    PolkieMan Posts: 2,446
    hmmm cruising around I wonder what the deal is on this?
    http://www.needledoctor.com/Music-Hall-Magic-II-Phono-Cartridge?sc=2&category=402
  • Hofy
    Hofy Posts: 169
    I used an AudioTechnica ML440a and a Shure M97xe on my Technics when I had it. They both sounded pretty good for spinning Led Zep.
  • westmassguy
    westmassguy Posts: 6,850
    Back in the day, I had an SL-1100A, with a Shure V15 Type V Micro-ridge stylus. One of, if not the best MM types available at the time. The V15 cartridges are easy enough to find, but getting a quality, after market Micros-ridge Stylus is another story. Most of what I see out there are Elliptical, which will work fine, but can't compare to the Micro-ridge. If you do find a Type V cartridge, and put an elliptical stylus in it, it's essentially a Type IV, but you'll always have the option to upgrade if you find a quality after market MR stylus.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
    I'm not a big TT guy but I do like that sound of that Shure cartridge. Mhardy had suggested a Grado somewhere on this site. Perhaps he will chime in as I can't remember if he actually gave a model number?
    cnh
  • bobt
    bobt Posts: 280
    No I like Grado stuff, when I was using the TT I did have a Grado I Liked, but can't remember what one. I had tried a big buck Otofon back in the day. But was not thrilled with that. I now have to pull the SL-1700 out of the closet and hope it still works, altho it has never failed to work, but you never know..LOL
  • Erik Tracy
    Erik Tracy Posts: 4,673
    You should add the Denon DL-110 to your shortlist.
  • bobt
    bobt Posts: 280
    Yeah, I've read some really good things about that. Since all of my records are old and over played and all classic rock, may not be a bad choice.
  • PolkieMan
    My Pioneer PL-510 sat for 15 years covered in the Magic closet, that's where old stereo gear becomes Valuable Vintage Items.
    I had to clean to speed pots and off she goes even since. I did get some new carts for it the Shure M97xe an Ortofon OM5 and a special cover from this place
    https://www.digitaldeckcovers.com/products.php?product=PIONEER-PL%252d510A
    bobt wrote: »
  • larry777
    larry777 Posts: 480
    I have used Shure V15 Type IV on my SL 1700 table with good results !
    Home Theatre.............
    Pioneer SC-35
    Polk RTi10's Fronts
    Polk CSiA6 Center
    RTi4 Surrounds
    SVS PB-12 Sub
    2 Channel.............................
    Yaqin MC-100B
    Energy RC-70 Speakers
    Arcam CD-192 Disc Player
    Van Den Hul Interconnects
