Sda srs 1.2tl
johnclayton
johnclayton Posts: 4
edited February 2014 in Troubleshooting
Is there any way to know if the posts in the back of the speaker are working correctly? My speakers were not used for YEARS and I am afraid that oxidation may have begun. The right channl speaker is weaker that the left. Especially in the high range. But the tweeters "Seem" to be working. They are the Polk SDA SRS 1.2tl. I would like to get the crossover board checked but dont know where to go. The local electronic repair shop guy looked lost when i talked to him so I definitiely am not taking it there...LOL SHould I start taking out screws and looking around? I dont want to start something and end up with pieces of speaker that I am unable to put back together :)
v/r
John
Post edited by johnclayton on
  • michaeljhsda2
    michaeljhsda2 Posts: 2,201
    Is the interconnect cable hooked up?
    SDA SRS 2.3TL's
    SDA 2B TL's
  • zane77
    zane77 Posts: 1,696
    PM Trey ( VR3 ) on this forum or get to him ar VR3mods.com, he can take. Are of all of your crossover needs and does fantastic work.
    Two Channel
    F1nut Posts: 51,783
    Either the polyswitch has failed or you have toasted a tweeter or more. Start with swapping the 3rd tweeter from the top with the same from the other speaker. If the right speaker now sounds correct then you have a bad tweeter. If it still sounds off then I would suspect a bad polyswitch.
  • VCoak
    VCoak Posts: 200
    Not to hijack but if you do the Vr3 x-over upgrade does that eliminate the polyswitch? I am about to purchase the upgrade and just curious.
    W4S SX-1000, Adcom gfp-750, Polk 1.2tl, W4S DAC 2 DSDse, 2012 mac mini (mod), JRivers ver. 19, WD Cloud NAS 2 t.b., Monster Cable AVS-2000 signature, Doug's Alpha I/C & Doug's biwire 6' speaker cables
    F1nut Posts: 51,783
    Yes.
  • Deadof_knight
    Deadof_knight Posts: 980
    I have a question what freqs does all of the 4 tweets play at since they all seem to be playing at a different volume or freq ?
    :cool: " He who dies with the most equipment wins Right ? "
    Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center
    ,HPSA-1000 18" sealed DiY home sub.:D
    Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables
  • PolkieMan
    PolkieMan Posts: 2,446
    The tweeters are line source all play in the lower range then they start shutting off as the freq goes up
    This will answer most of your questions Polk SDA Handbook
    http://vr3mods.com/uploads/SDA_Handbook_2011_Rev2.pdf
    I will tell u that you that my 2.3tls have lost two tweeters and one MW6510 in there lifetime but the
    crossover was okay just old and outdated. Empty paper towel roll works great for a quick by ear tester.
  • VCoak
    VCoak Posts: 200
    Thx F1. Can not wait to hear the old girls once I am done.
  • johnclayton
  • johnclayton
    Thanks to all for the quick replys. The difference in sound from let to right is pretty obvious. It "seems" that at least two of the tweeters are working (I will try the paper towel roll technique tonight). Does getting the crossover mods evaluated / checked / fixed cost a lot :) I am not floating in money but if the cost is reasonable I would certainly get it done. Also, when it comes to switching tweeters, is it reletively simple (i.e., 4 screws and a quick disconnect of a wire or two) or does it involve some deep understanding of electronics. To answer Deadof_knight' question, at any volume and or frequency there is quite a difference. One speaker sounds "alive" the other will produce good base and midrange but bad on the high range...This even though it seems at least one of the tweets is working fine. SOmetimes it is hard to dicern where the high range sounds are coming from (midrange or tweeter). Again, thanks for the responses. I will test them again tonight. Hope I am answering these posts correctly BTW. I used the "Post Quick Reply" command button.
    Toolfan66 Posts: 18,066
    Just pull a tweeter, and you will realize how easy it is, pull the crossover plate as well there is nothing to it.
    It's easier then changing the tire on a car, it don't take long to figure it out.
  • VCoak
    VCoak Posts: 200
    Also on my 1.2 the positive and negative binding posts per the sticker on the back of the speaker was incorrect. I just found this out after owning them for years. Check your speaker cable and make sure your polarity is correct.
    Pulling the tweeters is very easy.
  • michaeljhsda2
    When removing the crossover plate, only remove the 8 outer bolts. If you remove the single middle bolt, the crossover will fall off and smash into the passive radiator below!
    SDA SRS 2.3TL's
    SDA 2B TL's
  • johnclayton
    I will try to look at the tweeters and the crossover plate. As far as the binding posts are concerned I will check that also. How would I know if they are wrong...I guess there would be no or little output due to this. As far as the crossover plate is concerned, thanks for the info on the middle screw LOL, that IS a useful tip. Tonight will be a busy one.
  • VCoak
    VCoak Posts: 200
    Sound will improve. Switching them around will cause no harm. The positive/red will be on the left and negative/black on the right.
    F1nut Posts: 51,783
    It was only the 1.2's, not the 1.2TL's that had to red and black caps reversed.
  • leftwinger57
    leftwinger57 Posts: 2,917
    Jesse, Was any explanation ever given to the fact that Polk's color code is just about reversed in the low voltage universe. When I was installing house security systems red was alway + and black was always negative and if CAT-5 was used the solid wire conductor was the positive and stiped was neg. It made sense was taught like that in all the companies I worked for and never varied. If you used a different legend and was noted in the panel and back in the alarm panel then it was ok.
    F1nut Posts: 51,783
    Yes, they choose to use the high voltage color code.
    F1nut Posts: 51,783
    I should add to this. The SDA SRS is suppose to have the red on the right, black on left.
