Receiver upgrade help
bevo
bevo Posts: 306
edited February 2014 in Electronics
I'm thinking about upgrading from my denon 1909. I'm looking at the x4000 and it looks great. How much of a noticeable difference will there be? I think my setup is in my sig, it's been a long time since I've been on here so I'm not sure if it's still there it not.
Polk rti a5
Csi a4
Fxi a6
Svs pb13 ultra
I'm only running a 5.1 now but would like to add height channels.
Also are there any other receivers I should consider in that price range. The multeq xt32 is really the main selling point for me on the x4000 along with the decent amp and I have no experience with any other room correction systems except audyssey.
Any help would be great and if you suggest another brand would you please explain why it would be a better choice then the denon.
I should add I'm probably 40% music 50% gaming 10% movies. Music though is where I want the best sound if I have to choose but the addition of height speakers would be nice for gaming.
Denon 1909, want to upgrade for pre outs
Fronts-polk RTi A5
center-polk CSi A4
Sides Polk FXi A6
rears- polk rm8's
sub-SVS pb-13 ultra
Blue ray-ps3
Panasonic plasma 50 inch
Buttkicker(don't use or need it anymore since getting the Ultra)
Post edited by bevo on
  • mantis
    mantis Posts: 17,593
    With the speakers you own I suggest a Pioneer Elite SC-72. Go check it out
    http://www.pioneerelectronics.com/PUSA/Home/AV-Receivers/Elite+Receivers/SC-72
    Dan
  • bevo
    bevo Posts: 306
    mantis wrote: »
    I always wanted a pioneer but I've been afraid of them not helping to correct the sub. My room needs a bunch of help with the sub.
    Fronts-polk RTi A5
    center-polk CSi A4
    Sides Polk FXi A6
    rears- polk rm8's
    sub-SVS pb-13 ultra
    Blue ray-ps3
  • PSOVLSK
    PSOVLSK Posts: 5,407
  • drummer86
    drummer86 Posts: 441
    I've heard nothing but positive thing about XT32. I'm considering upgrading to it myself. Another route would be ARC in the Anthem MRX receivers. Never heard a bad thing about em either.
    Display: LG 47" LCD | AVR: Marantz SR5005 | BD: Panasonic BDT-210 | CD/SACD: Oppo 980 |
    Amps: Rotel RB-990bx | Marantz MA-500 | Speakers: Totem Mite : Totem Mite-C : RC60i | Sub: HSU VTF-2 MKIV
    HK AVR635 | Polk R30 | Sony DVD/SACD Player
  • bevo
    bevo Posts: 306
    PSOVLSK wrote: »
    I actually use to have one of those and sold it on here a few years ago.
    Fronts-polk RTi A5
    center-polk CSi A4
    Sides Polk FXi A6
    rears- polk rm8's
    sub-SVS pb-13 ultra
    Blue ray-ps3
  • maximillian
    maximillian Posts: 2,149
    Personally I am a fan of an external amp. Even an older, used 5 channel amp will outshine most AVR's internal amp. Those speakers will like more power (not talking volume here). Even if you drive only the L&R channels with a 2 channel amp and handle the other speakers via the AVR then it would be better. An external amp may make a better sound improvement overall.
  • gce
    gce Posts: 2,158
    I looked at the x4000 but went with the Marantz SR7008 because its more musical. If you go with the x4000 you'll hear a big difference because of the multEQ xt32. MultEQ xt32 is a big improvement!
    Anaheim Hills CA,
  • bevo
    bevo Posts: 306
    to use an amp I need a new avr. My 1909 has no pre outs. I've got a 2 channel adcom I'm going to try with it and if it improves the sound I will use it for my main speakers and buy a different amp for my bass shakers on my PC.
    Fronts-polk RTi A5
    center-polk CSi A4
    Sides Polk FXi A6
    rears- polk rm8's
    sub-SVS pb-13 ultra
    Blue ray-ps3
  • j1mmy
    j1mmy Posts: 95
    I like the Marantz receivers better than the newest Denons primarily due to build quality.
  • bevo
    bevo Posts: 306
    Accessories4less has the x4000 for a pretty good price. I went ahead and ordered one. I'm just really wanting to try the xt32 out. I couldn't find anything even close to the $900 price accessories had these for. Any other brand with similar power or features was much much higher in price. I should get it Monday and hopefully like it. I've already got my 1909 sold. They said they would pick it up as soon as I will let them have it.
    Fronts-polk RTi A5
    center-polk CSi A4
    Sides Polk FXi A6
    rears- polk rm8's
    sub-SVS pb-13 ultra
    Blue ray-ps3
