Question about Pioneer SX-737 receiver -
dromunds
dromunds Posts: 10,100
edited February 2014 in Electronics
I have a friend with a Pioneer SX-737 receiver who says the "radio bleeds into the phono and auxiliary. Anybody have any thoughts on what's going on? Also, can she connect a separate preamp to that receiver? Thanks in advance for any help.
Post edited by dromunds on
  • boston1450
    boston1450 Posts: 7,758
    edited January 2014
    I do believe radio shack has them (phono pre-amp) & can be hooked into AUX or TAPE if aux is messing up to. Or have it serviced is the best bet
    EDIT- have you tried deoxit on the controls ?
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
    mhardy6647 Posts: 34,921
    edited January 2014
    I don't think that the SX-737 has pre out/main in connections; I know that the previous model year's SX-727 does not.
    www.hifiengine.com may well have the manual.
    The radio bleed is an odd problem - maybe an issue with a dirty function selector switch?
  • [Deleted User]
    [Deleted User] Posts: 7,658
    edited January 2014
    Hello,
    One approach would be to select the FM muting button on the upper right of the front panel, then de-tune whatever radio station was selected. In effect putting the receiver's tuner between stations and with the muting engaged there won't be any sound. Then select phono or auxiliary with no interference.
    Ken
  • George Grand
    George Grand Posts: 12,258
    edited January 2014
    That is a cheap and effective fix for sure. Nice save amigo.
  • dromunds
    edited January 2014
    Thanks a lot guys. I'll pass on that suggestion Ken!
  • [Deleted User]
    edited January 2014
    I hope it helps your friend. Many internal input selectors will short out any non-selected sources, leaving the selected source connected. The problem can be with units that allow for one source to be recorded (or chosen as a second "zone" source) and another source chosen for main listening. This design would use a non-shorting selector and there could be bleeding of strong inputs.
    Cheers, Ken
    edited January 2014
    nice call, sir... obvious, but only in retrospect! :-)
  • George Grand
    edited January 2014
    This problem accompanied Carver HR-752 receivers right out of the box in the early 90's. There were a lot of them.
  • steveinaz
    steveinaz Posts: 19,545
    edited January 2014
    That wasn't an uncommon problem with receivers in the 70's/80's. I used to do what Ken mentioned, because I am supremely anal about background interference/noise.
  • boston1450
    Any update on this receiver ? I talked to my friend who has this very same receiver & he had the same issue & it came right out of it when he cleaned all the buttons & knobs. He has it hooked to a new turntable & tape player & is listens to FM alot. He really enjoys the Pioneer alot.
    Randy-Maine
    by David WMG
  • dromunds
    Boston: I passed on the suggestions and awaiting her response.
  • boston1450
    Cool. Hope she gets it fixed. Those are built nice & will go for years. Worth servicing
    Randy-Maine
    by David WMG
  • Speedskater
    Speedskater Posts: 495
    Over the decades lots of pre-amps had input cross-talk issues. Typically it happens when one input has a strong signal and then they switch to an input that has nothing connected to it. Try plugging a music sourch into the input, set the level for reasonable loud, then pause the music.
  • Mystery
    Mystery Posts: 2,546
    Almost all Pioneer silver face, Sansui, Kenwood, Technics and Realistic receiver of that time that I had always came with radio bleed.
    I had to use Phono button activated for a clean sound from other inputs.
