Just purchased a Musical Fidelity M6i Integrated Amp
I have different speaker cables than AQ I believe...I'll post late tonight when I get home. And yes...I think burn-in is next step
James2 Channel/HT:
Sony SS-M9 P's (ES version)
Sony SS-M1CN Center Channel
Polk RT800 Surround Speakers
Odyssey Stratos Dual Mono Amplifiers
TAD 150 Signature Tube Preamp
Harman Kardon HK354
Sony SACD Player -
Congrats!Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
Speaker cables are AQ Gibralter and the IC are AQ Sidewinders. Listening now, but at low levels.
James2 Channel/HT:
Harman Kardon HK354
Sony SACD Player -
James
The Gibralters are in AQ's "Flat Rock" series.
I used to run the Rockefellers which are one step down.
My experience - they were quite....revealing.
I'm currently running MIT Shotgun S2s and have better overall results in my system - more 'neutral' w/o giving up transparency.
I used to run the Sidewinders - very good value.
Also tried AQs King Cobras (muddled bass), Colorados(crunchy), and MITs Shotgun S3(loose).
Right now I'm using AQ Jaguars - the 'Goldilocks' for jusstt right.
F1nut has the best advice right now - let the M6i break in.
Experimenting with cables can come later.
It already sounds better than it did yesterday. I let the 'defrost' before running it, but it probably sat in a fed ex truck for a day. Maybe just coming up to a normal temp, and playing a lot will help.
James2 Channel/HT:
Harman Kardon HK354
Sony SACD Player
