Tube amp for RTiA7 speakesrs
Tilnot
Tilnot Posts: 4
edited January 2014 in 2 Channel Audio
Any suggestions would be appreciated. I currently have RTiA7's, C-J PV-10A preamp and Carver TFM-25 amp. This would be my first tube amp. The room is 12' x 16'. Thanks in advance.
Post edited by Tilnot on
  • marvda1
    marvda1 Posts: 4,903
    edited January 2014
    what's your budget and what type of sound are you looking for?
    Puritan PSM156
  • Tilnot
    Tilnot Posts: 4
    edited January 2014
    My budget is $2500. I mainly listen to jazz. I probably prefer more of a warmer sound, if that makes sense.
  • marvda1
    edited January 2014
    you are looking for a power amp?
    Puritan PSM156
  • Tilnot
    Tilnot Posts: 4
    edited January 2014
    Yes, a power amp to go with my preamp.
  • marvda1
    edited January 2014
    Puritan PSM156
  • brianle
    brianle Posts: 572
    edited January 2014
    Agreed! You'd be better to use that money to upgrade the speakers first
    tonyb Posts: 33,001
    edited January 2014
    DSkip wrote: »
    The M120 is a heat plant. It's nowhere near the design that the 150 or 180 is. Question: what is the rest of your system, from wall socket to speakers? $2500 on an amp to power some RTiA7's seems on the high end. No offense to Polk, but that amp will outclass the speaker IMO.
    +1000 here. You will not realize the benefit of amps in that class with those speakers. Not that they are bad, just tuned more so for HT than music.
    My .02, sell the CJ pre amp and the RTIA 7'S. Use that coin to upgrade speakers. Take the 2500 you have set aside and get a Musical Fidelity integrated, which will take care of the pre and power amp together and offer up some good SQ.
  • marvda1
    edited January 2014
    well, spend that $2500 on the usher dancer mini 2's for sale for $2700.
    Puritan PSM156
  • marvda1
    edited January 2014
    Puritan PSM156
  • Tilnot
    Tilnot Posts: 4
    edited January 2014
    Maybe I should think about upgrading speakers first. Then power amp. Thanks for the input.
