Rt2000i and Rt1000i worth repairing ?
Dropthebeat
Dropthebeat Posts: 154
edited January 2014 in Speakers
I've found a set of each rt2000i and rt1000i speakers for $100. The owner says one of the powered subs on each set doesn't work and one tweeter on one tower isn't working. Would these be worth buying for 100 in hopes of fixing them.
Yamaha V1800 receiver along with a NAD 2600a and 2700a .
Sda 1c - my new favorite speakers
Rta 8,11tl,15tl
Monitor 10 and 12
Marty sub 18" still in the works
Klipsch sw12-2
Hobbies turn into addictions .
Post edited by Dropthebeat on
  • dbKiller
    dbKiller Posts: 316
    edited January 2014
    At the least you could probably part them out and get way more than $100.
    Home Theater: LG 60PB450; Pioneer Elite SC55; RT2000P; RT55P; CS400p; FX500; SVS PB12-Plus/2; PS3 360GB
    Office: Onkyo TX-NR616; RT2000i; RT800i; CS400i; DSW Micropro 4000; XBOX 360 250GB; LG BR370; Panasonic Plasma
    Bedroom: Sony STR-DH820; CS400p; RT55p; Sony Grand Wega 55"
    Retired: Sony STR-DN840; Yamaha HTR-6130; Sony STR-DN520; Paradigm Phantom V.3; Paradigm CS-270V.3, Cinema ADP V.3, PS1000 V.4; Polk S6; Onkyo TX-NR809; Monitor 50, CS1; FXi3; PSW350
  • Dropthebeat
    edited January 2014
    What year are these speakers from ?
    Rta 8,11tl,15tl
    Monitor 10 and 12
    Klipsch sw12-2
  • dbKiller
    dbKiller Posts: 316
    edited January 2014
    I believe early to mid 90's. I have some 2000P's and they are 1999 models I think.
  • dbKiller
    dbKiller Posts: 316
    edited January 2014
    I have a moment, early 2000's, not 1990's.
  • Dropthebeat
    edited January 2014
    Man this hobby is quickly becoming an addiction . How do you like the sound they produce ?
    Rta 8,11tl,15tl
    Monitor 10 and 12
    Klipsch sw12-2
  • dbKiller
    dbKiller Posts: 316
    edited January 2014
    I have the 2000P's, the mids could be better, and for what they are the bass is solid and does well. Overall, if bought cheap enough they sound good. I do know the 2000i models got tweaked crossovers and a 100 watt amp as opposed to a 200 watt on the 2000p model. I. Haven't heard any i's, but I would imagine they sound as good if not better than mine. The 1000i models are similar to the 2000's, just use a smaller amp, and I think 1 6.5" sub compared to dual 8" subs in the 2000 towers.
  • HTguru1982
    HTguru1982 Posts: 1,066
    edited January 2014
    I think they're worth pumping in a couple hundred dollars. I enjoy my RT1000P's quite a bit, even thought one of the amps has a bad hum. I just turn the subs off and use only the top half of the speakers. I know some complain about the mid range but I find it to be very controlled. Great speakers IMO.
    I think there are a pair of Tri Lam tweeters on Ebay right now for $80. There's also a guy who repairs the amps for about the same price. I'd say get the RT2000 amp repaired and don't worry about the amps in the RT1000's.
    Display: Sony 42" LCD
    Sources: Harman Kardon DVD-27,
    Panasonic DMP-BDT110 blu ray player
    AVR: Sony STR-DA2400ES
    Amps: Sonance Sonamp 260(fronts),
    Kenwood KM-894(surrounds)
    Fronts: NHT 2.5
    Center: NHT VS-1.2A
    Surrounds: NHT Super One
    Subwoofer: SVS PB10-ISD
  • dbKiller
    dbKiller Posts: 316
    edited January 2014
    I agree and would look into fixing the speakers. I wasn't saying I wouldn't fix when I said the mids could be better. I really enjoy the speakers and the RT2000's look intimidating. But I am a big fan of the RT line anyway, so maybe I am just a little partial. I contacted Polk as one of my towers needed a tweeter, I believe Polk has new ones for around $85. I would fix them personally, just saying if for some reason you cant, you could part out and make some money. Good luck either way Dropthebeat.
  • mantis
    mantis Posts: 17,411
    edited January 2014
    Fix them, they are very nice speakers
    Dan
  • begbie
    begbie Posts: 630
    edited January 2014
    I picked up my rti series in 2000. The craze of the dvd era and hometheater seemed to really take off with dolby digital and dts decoding.
    Great speakers and yes it gets expensive as you want to build a 5.1 set with preferably a matching series.
    Polk Rt800i -Fronts
    Polk cs400i -Center
    Polk fx500i -side surrounds
    Polk rc60i -rear surrounds
    Onkyo TX-NR 1009 (9.2) receiver
    Velodyne cht12
    Polk psw111
    tonyb Posts: 33,072
    edited January 2014
    I'll throw in as the bad apple of the bunch.
    I've owned both those speakers, honestly you'd be better served with an old pair of RT55's and a decent sub. Another older similar sized big bookie is the Kef q60, paired up with a 505 subwoofer and I believe you can get better performance from either of the speakers your looking at.
  • dbKiller
    dbKiller Posts: 316
    edited January 2014
    I will agree with tonyb, I have the 2000's and 2 sets of RT55's I use. If you take the powered subs out of the equation, the RT55's are far better. I do enjoy my 2000's though. Find yourself a CS400i center and your golden. $100 for all, I would buy and fix.
  • Easy Runnin
    Easy Runnin Posts: 501
    edited January 2014
    I would get them in a heart beat, but I already have 2000s and 55s. I would then have plenty of spare parts. Fix the amp in the 2000 and keep the 1000 for spare parts. At the same time watch CL and eBay for another tweeter an/or amp.
    HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
    Rt35i Surrounds/Cs1000p Center/SVS BP1000 Sub
    2CH - B&K MC-101 pre/B&K EX-442 amp/NAD 2400 amp
    Polk SDA1C, Polk Monitor 7, New Large Advents and Polk RTA 8T
    BR - Yamaha CR800/Polk monitor 5
  • halo71
    halo71 Posts: 4,632
    edited January 2014
    I would snap them up for $100! But then again I like projects. My problem is completing them! lol
    --Gary--
  • dbKiller
    dbKiller Posts: 316
    edited January 2014
    Im with you Halo71 on projects, I have been tinkering with the idea of buying the mounting faces from RT55/800's and mounting the second driver in my RT2000p's. I freaking love these, have them for sale at the moment, but want to mod them. I am sure they wont sell because I want $400 for them, as I don't care if they don't sell, in very good shape. I love will always love the RT line.
  • halo71
    halo71 Posts: 4,632
    edited January 2014
    ^Well....ya know. I may just be able to help you out with those "mounting faces"! PM me when ya get a chance if you wanna talk.
    --Gary--
  • Dropthebeat
    edited January 2014
    well im picking them up this Friday, im hoping the cabinets aren't in too bad shape. seems like the owners had them in the garage for a very long time.
    Rta 8,11tl,15tl
    Monitor 10 and 12
    Klipsch sw12-2
  • Dropthebeat
    edited January 2014
    accidentally added a message and couldn't figure out how to delete it so here is this instead.
    Rta 8,11tl,15tl
    Monitor 10 and 12
    Klipsch sw12-2
  • Eocuph
    Eocuph Posts: 75
    edited January 2014
    Just the tweeters alone are worth the $100. I'd definitely buy them.
  • dbKiller
    dbKiller Posts: 316
    edited January 2014
    Check them over, humidity and RT speakers really don't get along. Either way, cant go wrong for $100 for all.
  • Dropthebeat
    edited January 2014
    Thanks everyone , always appreciate the advice . Have to say , this is probably one of the better forums around.
    Rta 8,11tl,15tl
    Monitor 10 and 12
    Klipsch sw12-2
