CHT 500 - Issue, in need of advice
bayfisher27
bayfisher27 Posts: 3
edited January 2014 in Troubleshooting
Thank you for reading my post. I hope I posted this in the right section.
Just purchased a refurb Polk CHT500 for the OfficialPolk Ebay Store.
Current Setup -
AVR Pioneer Elite VSX-52
POLK CHT500 - using it as a L/C/R since I have 2 separate surrounds in the back of the room. Part of a 5.1 setup.
Issue...once I turn on my system the speakers produce a loud 'pop' and no sound is heard. Then if I turn the AVR off again it 'pops' while it shuts off once. BUT...if I turn it on the second time, it does not do this? Basically if the AVR is left off for a period of time, the system produces a 'pop' at initial turn on.
SO...i though it was my AVR. I took it to a certified Pioneer Elite Service Center and it check out perfect! They said it sounds like the CHT 500 may be the issue, and the culprit could be in the SDA crossover. They said it could be a impendance issue.
Any ideas here? I am really at a loss here. Thanks for all your help in advance!!
Jeff
Post edited by bayfisher27 on
    F1nut Posts: 51,941
    edited January 2014
    The loud pop would be indicative of the sound capacitors make going from uncharged to charged when you power up the AVR and again when they discharge at power down. There should be a muting relay that prevents the pop sound being sent to the speakers. That relay or relays will be in the controller.
    CALL Polk to have the issue resolved.
  • bayfisher27
    edited January 2014
    Just spoke POLK's customer service department and they were extremely helpful!
    Take care!
    Jeff
    F1nut Posts: 51,941
    edited January 2014
    So, what was the problem?
  • fun_dador
    fun_dador Posts: 28
    edited January 2014
    Any update on what was the problem.
  • bayfisher27
    edited January 2014
    fun_dador wrote: »
    Sorry for the delay. It sounds like SDA module may have an issue. They are sending me a replacement to try. Great service!
