Dynamatting Rti12's and CsiA6
mufsoman
mufsoman Posts: 636
edited January 2014 in Speakers
I got a fresh sheet of Dynamat for my Rti12 drivers. Three questions though:
1) Should I Dynamat the tweeters? If so where on the tweets?
2) Anything else I can do with the 12's while I've got them open/drivers removed? Black hole, additional poly fill, etc? No cross over upgrades at this time.
3) I've noticed alot of resonance in my CsiA6 center channel cabinet. When I rest my hand on top of the A6, I can feel alot of vibration. Is this normal? Would some Dynamat on the inside top of the cabinet help or would it change the acoustics of the speaker?
Sony 83A80L TV and Roku Ultra
Denon 3800
Parasound HCA-2205A
SVS Prime towers, center channel and bookshelfs (side surrounds)
Atmos: Mirage Nanosats x 4
Turbo MFW-15 x 2
Panasonic DP-UB820
APC H15
Morrow MA4 & AQ Cobra IC's, AQ Midnight speaker cables
Post edited by mufsoman on
    F1nut Posts: 51,692
    edited December 2013
    1. No
    2. Possibly and no
    3. Normal, do not line the cabinet with Dynamat
  • Inspector 24
    Inspector 24 Posts: 1,308
    I've wondered about Dynamiting too….the SDA Guys slap it on all over the midrange drivers, and the PR, but I don't see any other speakers getting this treatment…why is that?
    Up
    LSi15 LSiC - RX-V3000
    Down
    Sim2 D60 - Dragonfly 106" Panny 500
    F1nut Posts: 51,692
    I added it to the drivers in my RTi A7, A6 and FXi A6's. You should too. :cool:
  • Hermitism
    Hermitism Posts: 4,321
    edited January 2014
    What about the basket on the subwoofer? Should that be done? I've seen threads about applying it to the drivers on the front and center speakers, but I haven't seen mention of this on sub baskets, unless I missed it somewhere.
    F1nut Posts: 51,692
    edited January 2014
    If it's stamped steel, then yes, but I don't think subs have stamped steel baskets these days.
  • Hermitism
    edited January 2014
    Does dynamat only work with certain metals?
    F1nut Posts: 51,692
    edited January 2014
    It's nothing to do with working with certain metals. Stamped steel baskets ring, cast aluminum baskets don't, so there would be no need to dampen them.
  • Hermitism
    edited January 2014
    Gotcha! Thank you!
