The office rig...
edited January 2004 in 2 Channel Audio
Since I work in a steel, brick and glass bldg., FM reception is almost impossible and our IT nerds have royally screwed up the network so I have to lay off net radio to save bandwidth. The soundcard on my office computer sucks and the aforementioned nerds will not let me install a decent one. It was getting bad without any tunes at work. You don't want to be anywhere near the doors at 5:00 PM or you get mowed down by the secretaries and AAs. I'm usually there till 6:30 or 7:00 and it gets pretty quiet. The acoustics are not really very good with several pics on 2 walls and floor to ceiling glass on the other 2 walls and it is about 15" x 15". I started looking around my basement and ended up with a pretty decent sounding system. I'm using a Sony Pro-Logic receiver with 100 wpc in stereo, a Sony single disc CDP, a pair of Mini Advent II speakers hooked up with Monster cables. As can be imagined bass response is a little weak but I can crank it up and hear it from one end to the other of a 10,000 sf. office. These little Advents put out some nice sound at decent levels. I don't have to worry about disturbing other offices because we're the only office on our floor and with concrete floors there is no sound traveling between them. I now look forward to 5:00 so everyone else can leave and I can pump up the volume.
Oh..and everyone that sees it thinks it is some "fancy" stereo but it is just odds and ends that are seeing duty again. I guess they are all used to boomboxes and mini-systems.
Here is a picture...the credenza sure looks better with the gear on it than it did stacked with files!
1.jpg 72.4K
Post edited by shack on
Welcome!
    edited January 2004
    Looking good, Shack.
    edited January 2004
    Nice lookin rig, Never seen/heard them advents....
    I, however would love to know how you were placed in a 15" x 15" office???
    Some reason, I dont think a computer monitor could get in there, much less a stereo. ;);)
    edited January 2004
    It may be small...but it is a CORNER office! And besides...I've been on the Atkins Diet.
    edited January 2004
    Looking good Shack. Did you place small rubber feet underneath those speakers? I noticed that it makes quite a difference.
    Maurice
    edited January 2004
    No. I might give that a try.
    edited January 2004
    I have read reviews regarding the Tivoli FM receivers and they are considered kick ****. I wonder if it would provide enough reception in your building?
    HBomb
    ***WAREMTAE***
    edited January 2004
    Shack......
    15" -- Is 15 inches ;)
    15'x15'
    edited January 2004
    Yes Sid........I know........I caught that from your first post....
    Maybe I should have used the :rolleyes: smilie...
    edited January 2004
    Dang.....
    I should go back to sleeping in class.....I feel so wired when i come home from the lack of naps........forgive me lmao
Welcome!
Welcome!
