Reasearching Amplifiers - Have a few questions for use with RTi speakers
msg
Hey guys,
I'm looking into amplifiers for the system I'm putting together. I'm not really sure what a good price point is, or what to expect in this area. Basically looking for something somewhat affordable to properly drive three channels right now. I don't just mean "good enough" - if I'm spending money on an amp, I'd like it to sound good all around, meaning, full & rich, with clarity at volume, and noticeably better than straight out of the receiver, so if "affordable" means "so-so, not really worth it/marginal improvement", I'll hold off for a while on that component. I'm seeing prices ranging from a few hundred, up through $3k, and that's about where I stopped looking, haha
I have a few questions. Can you guys help me out?
1. What are some good brands/models that work with the Polk RTi/RTiA line?
2. If I'm going to go with a 5ch amplifier, do I still need to spend money on a powerful AVR, or can I shop more for the feature set instead?
3. What sort of power should I be looking for to power a set of RTi10's, and a CSi5 or CSiA6? (3 channels total, for now; prob only ever going to have 5.1 at most, so maybe I only need a 3ch amp, unless a 5ch is only marginally more expensive)
4. What should I expect to spend on a 5ch amplifier?
Thanks in advance!
Thanks in advance!
Post edited by msg on
Pick a budget, multiply it by 10, then double it. It all depends on what you want. Quality and cost range from none to infinite.
I regard to question 2, if you get a 5 channel amp then you do not need an AVR. You need what is referred to as a pre/pro in the HT arena. Of course, an AVR with pre-amp outputs can be used, but in my mind you may as we'll maximize audio quality by using a pre/pro.
Power is like money. You can never have to much, but it is better to have quality power versus an inflated number. I think the Cfrizz rule of thumb (200 watts per channel) is reasonable.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
1) Parasound works well with RTi/RTiA.
2) No, but make sure it has pre-outs so you can hook up the amp or you could just get a Pioneer SC series and you won't need an amp.
3) 125 to 200 watts of good power should do the trick.
4) Depends on a lot of variables. -
thanks fellas.Pick a budget, multiply it by 10, then double it. It all depends on what you want. Quality and cost range from none to infinite.
Power is like money. You can never have to much, but it is better to have quality power versus an inflated number. I think the Cfrizz rule of thumb (200 watts per channel) is reasonable.1) Parasound works well with RTi/RTiA.
second time I've seen mention of the Pioneer SC series. seems like I could pick up one of these for less than the cost of a Preamp/AVR and an amplifier.
so I'm beginning to research the receivers, too. I'm a little confused at this point as to what makes a receiver good. I keep seeing stuff about "high power" or "high current" but not really sure how one goes about determining whether the receiver qualifies. the first inclination is to look at the power per channel, but apparently these numbers can be misleading, some manufacturers stating these specifications @6 ohms, or just 1 channel driven, etc. I'm reading the AVR FAQ and Amplifier FAQ over on AVS and picking up a few things. to complicate matters, I was sifting through some old equipment this morning and found my Dad's old Realistic Receiver that pushed some huge floor speakers with 18" woofers with a very warm, full sound, yet it was only rated at 25W/ch. ??? hahaI disabled signatures. -
With that speaker set you could get away with running everything from a higher end Pioneer SC ELITE ICE-POWER receiver. And it would still have the pre-outs necessary for adding more power if you wanted to.
It is generally NOT necessarily cheaper to buy a pre/pro and add amplification than to get an AVR and to do the same. Because most good pre/pros are higher end models made by the same people who make power amps.
The most budget friendly approach is to get a nice AVR and pair it with a USED multi-channel power amp of 200 watts or more per channel @ 8 ohms.
Those old Radio Shack receivers (I have a couple) weighed more than most mid-fi AVRs do today. And most of that weight was devoted to amplification (Transformers, Storage caps, heavy duty heat sinks, etc.). 25 watts x 2 could sound like a LOT more!
I have a 60 watt x 2 STA 2200 that weighs 36 lbs. And sounds fabulous, gobs of power on demand! Would put almost any contemporary 100 watt x 7 channel AVR to shame for two channel sound!
ADA makes some real nice units. Their AVR is one really sweet unit with ice power that will run 4ohms @300x7 all day.
Look them up, made here in USA and the sound is smoking hot and there would be no need to invest in all the other requirements
like cables and a pre-pro. But if your set for the pre and amp route then your quest starts now with a ton of choices that will do the job.
Dave -
cnh
yeah, I'm not sure why the wide spread in specifications for the old vs. new. have to read up on this.dave shepard wrote: »ADA makes some real nice units. Their AVR is one really sweet unit with ice power that will run 4ohms @300x7 all day.
DaveI disabled signatures. -
I am running a Pioneer Elite SC27 on rti 12 for fronts. Remember if you going to run a sub, you will most likely cross them over around 80 hz. That takes a big strain off of the receiver and it will go louder / cleaner vs running them at full range on a receiver.
For 2 channel, i will say it did suprise me also and was more musical then i thought it would be. You can also use the back 2 channels to bi-amp! I have owned mine for a little bit, ( Thanks again Leroy!) and i still have no idea all of what it does! LOL.
The Mcacc for HT setup, works ok but, i found it better letting it run its things and then going in and tweeking it for my taste. Since it has a few memory banks, I have one for HT and for music i run flat.Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's. -
holy crap man, just looked up that receiver you run - 140w/ch with all channels driven?!? nice!
and that receiver properly supports bi-amping? I've been reading conflicting points of view on this, but haven't researched the specifics yet provided in a link by F1NUT.I disabled signatures. -
You can pick them up used. For the $, on the used market, the SC Elite receivers are good!. There is a reason why people recommend them LOL. if your not using channels 6 and 7 through the setup it allows your to biamp
See page 22-27 http://www.pioneerelectronics.com/StaticFiles/Manuals/Home/SC-25_OperatingInstructions0421.pdf
This is one of thoes receivers that you HAVE to read the manual. Heck I still don't understand it all or everything on what it can do.
I am running a older Velodyne spl1200. Subs, there is soooooo much out there to choose from. It all depends on what you like.
For music, a seperate high current amp will do better but, honestly, the rti12 biamped via the 27 isnt that bad and I have heard worse.
BTW F1 is one of the people that recommended a pioneer elite for me.Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's. -
CNH, on the older realistic receivers, your right on! My 1st real receiver was a Realistic STA-820. I got it new on a radio shack as is where is sale when they closed it out. One of my friends had a Marantz 1060 and we did a sound off. Everyone back then actually prefered the sound of the Realistic over the Marantz. Many years later when I researched my 1st real receiver and found out it was made by Foster along with several of the TOL receivers thay had.Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
Excellent! I'll add this to my list. I hadn't really considered that there would be a viable market for used higher performing equipment, but I guess people are always upgrading.
haha, man, when it comes to this stuff, I ALWAYS read the manuals!
yeah, agreed, so much equipment out there. it's tough to sift through everything without being able to audition the pieces you're interested in. I think I'm learning that sealed subs are prob more geared toward HT than music, yeah? I prefer the lows to be a bit looser and to resonate some, but then, I'm going mostly by music. Maybe it's a configuration thing, but I feel like it drops off too fast sometimes in music with sealed subs. This is one of the reasons I'm looking at HSU - apparently they're highly configurable. trying to determine what size now, mostly. thinking a 12 minimum. my space isn't too huge, so that may be a good fit.You can pick them up used. For the $, on the used market, the SC Elite receivers are good!. There is a reason why people recommend them LOL. if your not using channels 6 and 7 through the setup it allows your to biamp
BTW F1 is one of the people that recommended a pioneer elite for me.I disabled signatures.
