N1 Surroundbar setup in Xbox One sound settings
Duff726
I am hoping someone could help me figure which setting would be ideal on my Xbox One. I have tried to set it up to be controlled by the system but there isn't a listing for the N1 Surroundbar, there is quite a few selection under Polk though. Any direction will help.
Thank you in advance.
I called Poke and was told "oh it's not supposed to be controlled by the Xbox One". Seriously, thats what I was told. This "compatibility" gimmick for this product didn't really happen.
I'm actually really frustrated by this. The modes can be used with any system not just xbox one, which is nice but proves they are just EQ settings. There is also a list of a whole bunch of other Polk products that can take commands from the Xbox One, so its really odd how the product that Polk "partnered" with MS on isn't supported. Just venting my frustration. Other that this, I am quite pleased with the soundbar.
Found a workaround. Train your N1 to take a volume signal from your TV remote. If you have your Xbox One setup to control your tv, you can use the volume function on the xbox one to control the volume of the soundbar.
