does sunlight damage drivers
dongar
dongar Posts: 7
edited December 2013 in Vintage Speakers
I have my SRS speakers exposed to sunlight from a south-east facing picture window and I would like to keep the grills off of them. I am concerned that the light may damage the drivers if they are left uncovered. Does anyone know if this is something to be concerned with? Thanks Don
Post edited by dongar on
    F1nut Posts: 51,786
    Sunlight damages everything.
    I never could understand why people like to look at the drivers. If you're looking at them while listening to music, you've never actually listened. That said, dust and grime in the air will damage the drivers as well.
  • nguyendot
    nguyendot Posts: 3,594
    rofl I was literally thinking that exact sentence F1 before I even clicked on the thread.
    Main Surround -
    F1nut Posts: 51,786
    :cheesygrin:
  • westmassguy
    westmassguy Posts: 6,850
    dongar wrote: »
    The most vulnerable parts are the rubber surrounds. They're attacked by the oxygen in the air, and household pollutants, that's why you'll see brown oxidation on them. The heat from sunlight, and the UV rays will only accelerate the deterioration, by drying out the rubber. The grills protect them from this to a degree, and also from curious little fingers that love pushing in dust caps.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • Mr. Bubbles
    Mr. Bubbles Posts: 736
    What F1 said. I was thinking the exact same thing as well before the thread actually opened and then saw my thoughts right there. Also like what i believe F1 was eluding to; get in the sweet spot, close your eyes, and get lost in the music.
  • oldmodman
    oldmodman Posts: 740
    It sure does.
    I am reminded daily that it's time for new curtains. "They look terrible. They are all sun faded"
    As if I give a rats **** how they look from the street. As long as my Hi-Fi and flat screen look good I don't care.
    But you could get that UV prevention film installed on your windows. It can eliminate 98% of the UV and over 70% of the infrared.
    pitdogg2 Posts: 27,058
    oldmodman wrote: »
    Great stuff ....that is unless you have plants then they don't do so good....
    Toolfan66 Posts: 18,067
    What does common sense tell you?
  • jon s
    jon s Posts: 905
    Another big issue... If you have a veneered finish, the sunlight will lighten the colors of the veneer. This is more noticeable on cherry. I have a pair of KEf 104/2 and the left speaker is a LOT lighter than the right...
  • seabeerob213
    seabeerob213 Posts: 1,843
    UV damages and kills everything, causes cancer, spontaneous combustion, and in rare cases, shows embarrassing stains on your sheets.
    F1nut Posts: 51,786
    jon s wrote: »
    The sun will bleach any wood be it solid or veneer and no matter what the type. However, in most cases with a finished item it is not the wood (at least not at first) that is affected by the sunlight, it's the color (stain, dye, toner) that is being bleached.
    A side note about cherry, which is a fairly light wood, when left unfinished and out of direct sunlight wll, over time, turn much darker.
