Looking for my first serious turntable!
thetawave2
thetawave2 Posts: 268
edited January 2014 in Electronics
I'm currently in the market for a turntable (with a cartridge). My budget is $1000-$1500. I am very strongly considering the VPI Traveler, having read an absolutely glowing review from Stereophile's Stephen Mejias (http://www.stereophile.com/content/vpi-industries-traveler-turntable). Any thoughts on this table or the VPI brand generally? Any other tables you think I should look at? Please let me know!
My Stereo: Tannoy D100s, Yaqin MC-100B, VPI Traveler, Dynavector 10x5 MC Phono Cartridge, heavily modified Yaqin MS-22B phono preamp, TEAC EQA-20 equalizer, Belkin PureAV PF30 Power Conditioner, Canare 4s11 speaker cables, Custom dust cover from DigitalDeckCovers
Post edited by thetawave2 on
  • mrbiron
    mrbiron Posts: 5,712
    edited December 2013
    You'll be hard pressed to find that table plus cart in your range. Used come up very seldom as I look.
  • Mikey081057
    Mikey081057 Posts: 7,127
    You could easily double that budget to add a cart and a phono re that would be suitable for that table
    Garage | Polk Monitor 5B's
  • Mikey081057
  • mrbiron
  • Obsession18
    Obsession18 Posts: 191
    I own version 1.1 of the Traveler, great table, but it does have it issues with loosening tonearm gimbal bearings, I check it monthly to make sure everything is in order. The latest version of the Traveler (2.0) replaces the subject bearings with roller bearings as opposed to a pin in a hole set-up. The version 2.0 traveler will set you back $1500, where as an older version 1.1 table can be had for about $1000, check around some online retailers still have the older table available. Performance will be the same with either table, the review you linked is actually the version 1.0 table.
    2-Channel System
    Analog: VPI Traveler TT, Audio Technica 150MLX, Pro-Ject Tube Box DS
    CD Player: Jolida JD-100 Preamp: Cambridge 840E Amp: Odyssey Kismet Stereo
    Spkrs: Tyler Acoustics Linbrook Signature Systems
  • thsmith
    thsmith Posts: 6,082
  • thetawave2
    Thanks for the input, guys! I should clarify; the budget I gave is for TT only. I'll probably be looking for a cartridge in the range of $100-250 for now, and I already have a phono preamp. I'll take a look at some of the links that have been posted after work. Rega in particular was a brand on my shortlist.
    There's a VPI dealer pretty close to me! Might be placing a call to see what they have in stock and pay them a visit this weekend....
  • nspindel
    nspindel Posts: 5,343
    I have the Traveler and I love it. I also have a VPI record cleaning machine (the 16.5) and love that as well. I have been to VPI's headquarters in NJ, met the folks there, and can't say enough good things about them. The Traveler was just named Stereophile's product of the year. If that's your budget for a table, the Traveler is a no-brainer. I have a Grado Sonata on mine, and the sound is incredible.
    The problem with the loose gimbal bearings was solved by VPI, my table has no issues there. Obsession18, have you contacted VPI about sending your tonearm in to them to have serviced or replaced?
  • 4xoddic
    4xoddic Posts: 372
    thsmith wrote: »
    That Marantz (Clearaudio) comes with a CA Virtuoso cart. worth ~$895. HiFiHeaven was offering the TT-15S1last month for $999 (mine came with a Gingko cover for < musicdirect's price. I'd give them a call, as it's no longer on their site.
    http://www.stereophile.com/phonocartridges/737
    http://audaud.com/2008/11/the-wonderful-world-of-vinyl-marantz-tt-15s1-turntable-reviewed/
    http://www.musicdirect.com/p-106168-clearaudio-virtuoso-v2-ebony-mm-cartridge.aspx
    http://www.vinylengine.com/turntable_forum/viewtopic.php?p=103604
  • Obsession18
    nspindel wrote: »
    I've been debating whether or not I want to contact VPI about my bearing issues, I've had the table for a year now and other then tightening the bearing screws up once a month the table has been great. I wonder if they would provide me with one of the newer arms, I guess the only way to find out is to contact them.
    2-Channel System
  • nspindel
    Definitely contact them.
  • mrbiron
    In that case....clear audio concept and don't look back!
  • doctorcilantro
    doctorcilantro Posts: 2,028
    Shameless plug?
    http://www.polkaudio.com/forums/showthread.php?155404-Interest-Check-Technics-1200-Audiomods-Classic-mods
    I too considered the Traveler, but I ultimately thought a used table of higher caliber would provide more bang for the buck.
    No doubt it is a sweet table though.
    For Sale 2019:
    Tortuga Audio LDR passive preamp
    Decware EL34 amp
    Allnic H-1201 phono
    Zu Union Cubes
    iFi iDSD DAC, .5m UBS, iFI Gemini cable, Oyaide Tunami XLR 1.3M, Oyaide Tunami Speaker wire 1.5M, Beyerdynamic DT1990 headphones, PS Audio P3 power center
  • thetawave2
    Shameless plug?
    Yeah I'm definitely considering used as well. Paying a visit to a local stereo shop on Saturday and hopefully they have some nice used models in stock.
  • thetawave2
    I'll be demoing a Rega RP6 and a VPI Traveler on Saturday!
  • dbaldus
    dbaldus Posts: 730
    thetawave2 wrote: »
    Definitely interested in hearing your comparison of the two. I'm in the same situation as you and have those 2 plus the Music Hall 7.1 on my list.
    2-channel
    Squeezebox Touch| MSB Analog DAC | Audio Research Ref 40 Anniversary Edition| Pass Labs X350.8 | Wilson Audio Sasha 2
    Arcam AVR 550 | GoldenEar Triton One | GoldenEar SuperCenter XXL | GoldenEar Aon 3 | JL Audio Fathom F113v2
  • nspindel
    You should make sure to listen to them with the same model cartridge, through the same phono pre, etc. You need to hear an apples to apples comparison.
  • thetawave2
    nspindel wrote: »
    That would have been my thought initially, but I'm looking to buy a cartridge to go with the table. The man I spoke to at the shop said he has different cartridge recommendations for each table, so I'm going to go with his expertise on that one. Definitely going to ask detailed questions about why each cartridge goes with each turntable, though. Since I already have a preamp, however, I do hope he uses the same phono stage for each.
  • nspindel
    I don't buy that for a second. Too easy to stage the more profitable table to sound better.
  • thetawave2
    nspindel wrote: »
    That's one way of looking at it, sure. However, the tables are very close in price and I'm a big believer in system synergy, so I'll follow his lead on this for now. If I get the sense that he's actually just trying to squeeze as much money out of me as possible, I can always just leave. Maybe I'm being a little na
  • nspindel
    Most expensive and most profitable aren't necessarily the same.
  • Dawgfish
    Dawgfish Posts: 2,554
    It can be tough to make an apples to apples comparison between two turntables with the same cart sometimes due different masses of turntable arms and different compliances of cartridges. For example a cart with low compliance such as a Denon DL103R may sound great with a heavier arm such as those that come on the TTweights tables and others, but not work so well with a lighter arm such as many of the Regas. The opposite would be true comparing a higher compliance cart like a Grado reference cart. Synergy is important with all equipment but especially so with the relation between a cart and a tonearm.
    The thing to do is research the different tables with regard to tonearm mass and if you are going to do a comparison using a single cart on different tables, try to use a cart that would be a decent match for all. Having said that, you have to realize that a cart may be a better match for one table over another because of the tonearm mass/cartridge compliance relationship. It's something you will never completely get away from.
  • nspindel
    Then how do you make an objective decision about a turntable?
  • Dawgfish
    Again you try to use a cart that would be a decent match for both and go from there. You will never completely get away from the tonearm mass vs cartridge compliance issue though. You can't overcome physics. An alternative way to decide would be to compare the two tables using a cart you would be using and go from there.
    I tend to look at other factors when deciding on turntables such as build quality, type of drive, materials, adjustability, potential for future upgrades, and history plus customer service of the manufacturer of the table. Being perfectly honest the looks and coolness factor of the table has a big bearing (no pun intended) in the decision also. The OP has lots of good choices in his price range, he'll decide what's best for him based on his criteria, which may not be the same criteria that either one of us or any others would use. As long as they are happy with it in the end, that's all that matters.
  • thetawave2
    Well I did a lot of listening to the Rega RP6 and the VPI Traveler today and it was a pretty tough choice. The RP6's cartridge was Rega's match for it (I forgot the name) and the Traveler was equipped with the Dynavector 10X5. I talked for a long while with the salesman about the differences between the two turntables (rigidity vs. mass damping, et c) but the listening was really where my decision was made. And a tough decision it was! Both TT/Cart combos had very different characteristics and I found it difficult to choose for a long time. The Rega/Rega was a bit more forward, a bit more lively. Attacks could be startling in a very exciting way. It was more of a thrill. The VPI/Dynavector was a bit more laid back, a bit warmer, and was much better (I thought) at conveying emotion. After thinking about it for a while, I realized that I really liked both turntables for different reasons, but the VPI's more emotionally nuanced presentation was the one I'd want to bring home.
  • hochpt21
    hochpt21 Posts: 5,423
    Congrats on the decision. I have a feeling you will be very happy...
  • nspindel
    Congratulations. Welcome to Club Traveler!
    FYI, I can tell you that the two cartridges VPI seem to recommend most for the Traveler are Grado and Ortofon. I've got the Grado Sonata, and I listened to an Ortofon when I visited their headquarters. Both will put a smile on your face. I've not heard the Dynavector, but I'd advise you to try to get your ears on the Grado and Ortofon before making a final decision.
  • Dawgfish
    Congrats! It's hard to go wrong with VPI or Dynavector for that matter! You should very happy with that combo!
  • nspindel
    By the way, if you are on facebook:
    https://www.facebook.com/vpiindustries
