Powering LSI9's
Ginn
Ginn Posts: 46
edited December 2013 in 2 Channel Audio
Hey guy's,
Do you think the Cambridge Azur 640a will be enough to power a pair of LSI9 speakers for audio, or do you think they need more juice?
If not what would you recommend?
http://www.hifiengine.com/library/cambridge-audio/azur-640a.shtml
Cheers,
HT - Sony 52" Bravia - Onkyo TX-NR3008 - Emotiva XPA-5
LSi15 - LSiC - LSifx - PSW505 - Mac Mini
Warehouse Boxed up RTIa9 - CSIa6 - FXI6
Office
LSI15 - Peachtree Preamp / 220 - iMac
LSi9's sitting around my dad's house
Post edited by Ginn on
    tonyb Posts: 33,001
    edited November 2013
    I would say it's on the light side. Parasound, B&K, would be my top 2 choices,
  • marvda1
    marvda1 Posts: 4,904
    what's your budget?
    Puritan PSM156
  • Ginn
    Ginn Posts: 46
    I already have a big ht system so I was hoping to stay under $500.
    There is this used store right by my place with some sweet old unit's. I just don't know what's good from back then.
    Take a look and let me know if you see something under Integrated amps or receivers.
    http://www.iavscanada.com/shop/
    Office
  • marvda1
    Puritan PSM156
  • FTGV
    FTGV Posts: 3,649
    The impedance of the 9's dip into the 3 ohm range in the bass so you will want an amp that can deliver some current into low impedances.The spec sheet for that Cambridge gives only a rating into 8 ohm's so is not likely to be a good match.
  • Ginn
    Ginn Posts: 46
    It says Load between 4 - 8 ohm? See below
    Power output: 65 watts per channel into 8Ω (stereo)
    Frequency response: 4Hz to 80kHz
    Total harmonic distortion: 0.07%
    Signal to noise ratio: 92dB (line)
    Speaker load impedance: 4Ω to 8Ω
    Office
  • Ginn
    Ginn Posts: 46
    Office
  • Mikey081057
    Mikey081057 Posts: 7,127
    I drive my VR3 9's with 30 watts of tube and they are sweet.
    Garage | Polk Monitor 5B's
    tonyb Posts: 33,001
    I don't think the OP is asking about tube watts. If he wants SS, the Cambridge is a lightweight.
    It's CURRENT you seek, not WATTS !!
    tonyb Posts: 33,001
    Ginn wrote: »
    Dude has a Parasound 1200 that would work, the Adcom 555 would work too.
  • Ginn
    Ginn Posts: 46
    I might be able to get my hands on a used one of these. Thoughts?
    Peachtree nova 125
    http://www.peachtreeaudio.com/nova125-amplifier-with-dac.html
    Office
  • PSOVLSK
    PSOVLSK Posts: 5,220
    I powered my 9's with a Nova. Never an issue and I thought they sounded great together. Would still be running them, but I moved on to the 703's. Love my Nova.
  • Zitro
    Zitro Posts: 864
    DSkip wrote: »
    That's a very nice amp...I'm taking a road trip to Vancouver on Sunday and if you don't take this, I may pick it up ;)
    - Jeremy
    Amps: Jolida FX-10, NAD 3045, NAD C320BEE, Sansui G-9700
    Speakers: Polk Monitor 7A's, KEF Reference 104aB
    Sources: ProJect Debut Carbon, Sonos streaming FLAC
  • cmy330go
    cmy330go Posts: 2,341
    I think it would be fun to know how many threads have dealt with this exact topic. Honestly not trying to start crap, just think it's funny that after quite a long time away from the forums, that this question is still being asked.
    HT
    Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
    2 CH
    Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
  • steveinaz
    steveinaz Posts: 19,538
    The BIG question: How loud do you want to listen?
  • Ginn
    Ginn Posts: 46
    That looks good but I have no knowledge of tube amps.
    Will it give the speakers enough power? Will it be quality or loudness?
    Office
  • markmarc
    markmarc Posts: 2,309
    I can tell you without a doubt the Peachtree nova125 will be able to handle the Lsi9's. When I reviewed the nova125 for ToneAudio, it matched up very well with my Magnepan 1.6's which are notorious for dropping into 2 Ohm territory on a regular basis. In addition, if I sell off my current system to free up cash, the nova 125 would by my integrated amp/DAC choice.
    I also HIGHLY recommend modifying the x-overs, the stock ones in all due honesty are disappointing in comparison to the rest of the components.
    Former Staff Member TONEAudio
    2 Ch. System
  • cfrizz
    cfrizz Posts: 13,415
    Ginn wrote: »
    I would go for both quality AND the ability to go loud when the mood strikes.
    Hook up your Emo to the LSIs and that will tell how good they can sound with that much power. I would say stick with SS power of at least 200wpc @ 8ohms.
    While everyone around here preaches current, they ignore the fact that more wpc = more current. LSIs require more power/wpc simply because they are 4ohms the more power you give them the better they will sound. It is worth the extra money to ensure that your 9s operate to their full potential. And the amp can be used for any other upgrades you make to speakers.
    So stalk Audiogon until you find what you need.
    tonyb Posts: 33,001
    Um...no Cathy, more watts doesn't necessarily mean more current.
  • cfrizz
    Please show me examples Tony in SS gear. Thanks.
  • Devlon
    Devlon Posts: 355
    After getting an opportunity to talk with Andrew Robinson of Home Theater Magazine who uses Crown XLS1500's to power his Tekton Pendragons I decided to order one. Now I have 3. They make my Lsi's sound the best they have ever sounded. 8.9 lbs and 525w per side at 4 ohms. The best and most versatile amps I have ever owned. I got my first one used on Ebay for about 250.00. Here is a link to guitar center's site that gives some specs:
    http://www.guitarcenter.com/Crown-XLS1500-DriveCore-Series-Power-Amp-105914915-i1516455.gc
    Living Room: HK AVR 354 as pre/pro, 2 x Polk Audio Micropro 4000, Adcom GFA-7500, 2 x Mirage OMD-15
    2 x Mirage OMD-5, 1 x Mirage OMD-C1, APC H15, Sony S790, Philips 52" LCD, Beogram 3000, FAT (Firestone Audio Tobby DAC), Harmony One
    Den: Sherwood R-972,as pre/pro, 2 x Velodyne SPL-1000R, 3 x Crown Drivecore XLS1500, 2 x Polk Audio Lsi9
    1 x Polk Audio Lsic, 2 x Polk Audio Lsifx, Sony S790, APC H15, Dspeaker Dual Core 2.0, W4S DAC 2, Keces DA-151
  • aboroth00
    aboroth00 Posts: 1,106
    cfrizz wrote: »
    For example if amp 1 and amp 2 are rated 200wpc and 150wpc @ 8ohms and 250wpc and 300 wpc @ 4ohms, respectively, amp 2 has more current because it's doubling its wpc when the resistance is being dropped by half. So it's a little deceiving.
    2Ch Tube Audio Convert
  • cmy330go
    I guess the blanket 200wpc claim is still alive and well too. ugh.
    HT
    2 CH
    F1nut Posts: 50,734
    cmy330go wrote: »
    Hehe........
  • Ginn
    Ginn Posts: 46
    The Peachtree ended up just being the original one with only 80w. Plus I don't think it can go down to 4ohm.
    The search continues……….
    Office
  • FTGV
    FTGV Posts: 3,649
    cmy330go wrote: »
    I guess there's a sceptic in every crowd.
  • aboroth00
    cmy330go wrote: »
    If it was 20 years ago it would've been 100 watts... I'm sure in maybe a couple years, it might be upped... 500 watts maybe?
  • cmy330go
    FTGV wrote: »
    Must be some pretty tasty Kool-Aid.
    aboroth00 wrote: »
    LOL. Could very well be, and I'm sure there will be a whole new batch of people that won't understand why it's not necessary.
    HT
    2 CH
  • steveinaz
    Well, saying an amp has "too much power" is akin to saying your car can go "too fast." I'm not seeing a downside. However, if you listen at moderate levels, and your amp is spec'd for 4 ohms loads; and you have a satisfying level of "headroom" for your listening habits, more power does NOT mean better power in many cases. I think anyone with a Pass Labs 30w amp can attest to this.
    It's like any hobby, look for the amp that meets your specific needs (speaker efficiency vs desired listening levels)--but be realistic in your expectations.
  • Ginn
    Ginn Posts: 46
    So I went down to the local A/V shop and grabbed the Cambridge Azur 651a just to see what would happen.
    It has 125wpc at 4ohm and seamed like a decent Int amp. I compared it with my current emotiva putting out 300w at 4ohm.
    I know a lot of people talk about wpc and how much you really need, along with int amps vs preamp and amp combo.
    So here's what I thought….. and I had a good buddy with me who had the same opinion.
    The emotiva mixed with my ht onkyo amp was full detailed, great soundstage, plenty of volume and punch, and we found it could go louder if we wanted.
    The Cambridge sounded flat, no detail, soundstage was ok but nothing special, and if you tried to push the volume, which was over 3/4 on the knob, it sounded muffled.
    I know there is a difference between watts and quality watts. My opinion is if you are going to spend 1000+ on an int amp I'm sure you can get something decent, but if you have a budget you will have to go with a preamp / amp to drive these speakers.
    I would love to grab a peachtree nova125, but for half the price I can get a XDA-2 preamp with built in DAC and a XPA-200 which will push 240w x 2 at 4ohm.
    I think that's the way to go. That's just my 2cents.
    Office
