Excellent Rotel RC 990BX preamp remote controlled
geppy1
For sale, excellent Rotel RC 990 preamp. This was Rotels top of the line ($750) preamp from the mid 90s. It has 6 inputs including a very nice phono stage that accepts MM and MC. as well as 2 preamp outputs for running two power amps. I do not have the original remote which just controlled the power volume and mute. The unit can be remote controlled for power, volume and mute. I have used a $15 universal remote and it did control the power volume and mute which is all the original did anyway. In excellent shape and everything works as it should. There are a few scratches on the top from gear being set on it. .. This is a top shelf preamp and performs as such. Asking $275 or BO Thanks,keith
FYI I cannot get the pictures to up load
Post edited by geppy1 on
You need to change your "Quick style" to test“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain
I too am having trouble uploading pics tonight.
Im sure it will be cleaned up soon enoughhumpty dumpty was pushed -
Sold
