What are your experience with LSiM made qualitiy?
venicebeach
venicebeach Posts: 31
edited January 2014 in Speakers
Hello
did u have trouble with your made quality from your LSiM speakers?
Post edited by venicebeach on
  • Dawgfish
    Dawgfish Posts: 2,554
    edited November 2013
    The build quality on my 703s is outstanding, especially in their price range.
  • PSOVLSK
    PSOVLSK Posts: 5,400
    I have 2 sets of 703's, a 706c, and 702f/x. Build quality on all are superb and as Dawgfish said, especially in their price range.
    Hello
    Why....are you having issues ?
    F1nut Posts: 51,997
    Every LSiM speaker I have seen and/or have had in my hands has been extremely well made.
  • Conradicles
    Conradicles Posts: 6,376
    Dawgfish wrote: »
    My thoughts exactly. Fantastic quality.
  • jtshaw43
    jtshaw43 Posts: 161
    I have a pair of 707's(soon to buy a second pair nxt wk) a 706, and 2 pair 0f 702's. and the build quality on all of them is outstanding. they look d#*m good if I might add!
  • Mikey081057
    Mikey081057 Posts: 7,127
    My 703's are built well,,, only issue is you will have a hard time finding stands with a large enough top plate to adequately support them... If I was to do it all over again I would have bout the 705s for a few hundred more during the F&F sale last summer.
    Garage | Polk Monitor 5B's
    F1nut Posts: 51,997
    Skylan stands.....custom sized to order.
  • Mikey081057
    Gotem...thnks to you... but they are not cheap..if i add it all up... for about $400 more i coulda woulda shoulda got the 705's...
    F1nut Posts: 51,997
    Ah so.....LOL
    You do have an excellent point. :cool:
  • mantis
    mantis Posts: 17,559
    That has always been my issues with Bookshelf speakers vs floor standing. Shame as most of the time the entry level floor standing speaker of the same line always seem a bit lacking in overall sound quality vs the bookshelf. But then again I never go entry level anything so I would just go for the 707's if I where to go LSIM's.
    I only heard the 703's as I had them here during the demo program and I thought they where built extremely well especially in the price class. I found nothing wrong with them. I would love to get my ears on a pair of 707's and a full HT setup.
    Dan
    VR3 Posts: 29,549
    My favorite of the line is the 705. The 707 is just too much
  • WLDock
    WLDock Posts: 3,073
    VR3 wrote: »
    I would like to hear how the 707's sound in a modest sized room. So many report that the low end is too much. I wonder how the output compares to the RT3000P's? I can see how many would think that those are too much also.
    Anyway, the 703 is just a super bookshelf. A three-way that can go low...
  • venicebeach
    Hey
    Hm well I have the 707 706c and the 702 F/X.
    They are well made but with problems.
    On the one 707 is the front ( black one) angular. On the other one is on the back a dent from polishing at the factory I guess.
    From the 706c grille came after unwraping the protective sheet the POLK emblem off. The glue doesn´t hold the emblem.
    and one 702 hast a painting drop at the bottom.
    Well maybe I´m to picky but for this price there shouldn´t be problems like this. The biggest thing which bothers me is the black front at one of the 707 :(
    My dealer said that is maybe the manufacturing tolerance, but sorry not at this price range. He contacted Polk. I´m curious what Polk `ll say.
  • teekay0007
    teekay0007 Posts: 2,288
    ALL of the several LSiMs I've seen and heard have been in pristine condition without defects of any sort, even under very close inspection. And, the quality and workmanship of this series has been on par with other brands that are priced at multiples of the Polks' prices. Since you have a local dealer, I'd take it up with him. From your other post about your setup, it sounds like you just recently got them. He should be willing to replace/exchange them for ones that are more to your liking, or at a minimum, give you a discount on the ones you already have while at the same time helping you to make them right - ie. fixing the emblem issue, etc.
  • Mikey081057
    DSkip wrote: »
    You were better off with the 703's in your room. The 705's would've been overkill and not performed to their ability.
    But I like being overkilled!
    F1nut Posts: 51,997
    Hey
    Sounds to me like your dealer got some factory seconds instead of factory perfects. He should exchange them.
  • pretzelfisch
    pretzelfisch Posts: 160
    I have four 703 off of polks ebay store the worst one has a small scratch on the bottom of the speaker. And the 704's grill does not fit quite right.
  • enricoclaudio
    enricoclaudio Posts: 22
    I have my 703s on Ultimate MS-90/36. These are the best speaker stands I ever had.
    Watch out the size of the plate!!!
    http://www.ultimatesupport.com/product/MS-90-36B
  • Dawgfish
    ^^Those are nice!^^ They seem to be priced right to. Nice system!
  • venicebeach
    edited December 2013
    so I got a discount for the speakers. :) That´s ok I guess.
  • argylesox
    argylesox Posts: 48
    I can recommend this place for speaker stands made to your specifications:
    http://www.skylanstands.com/stands.htm
  • RamZet
    RamZet Posts: 792
    edited January 2014
    Hey
    I would like to know what they are going to say.
    Im going to buy a pair of these in 2014. I get them for dealer pricing ( the markup is insane btw). What makes me want them is the build quality. I think polk has made a nice product. I am a bit concerned that when I have the money to order mine that I might have to return them for replacements b/c of factory defects.
    B&W CM9Classé Sigma
    F1nut Posts: 51,997
    edited January 2014
    You really posted that....really!?!
    There's a chance of an issue with anything you buy, so if you don't buy anything you won't have to worry about an issue.
