Monitor 60's zone 2
ibewbrother
ibewbrother Posts: 186
edited November 2013 in Troubleshooting
I fired my M 60s and had no tweeters....the left came in and out.....staticy....right was nothing. I pushed as hard as the SC57 would go...... Bad tweeters? Add an amp...... bad hookup?
Any feedback greatly appreciated
Thanks in advance....
Brother
"Making life enjoyable through expensive electronics." BillD
Pioneer Elite SC-57
M70 series 2 mains
CS2 center
M40 surround
M30 front height
SVS PB 12 NSD
Carver TFM-45 (mains)
Carver A753x (center, surround)
320GB PS3, 42" Panasonic G10,
M60's as a Zone 2 off of the Pioneer in the living room
R.I.P. Onkyo TX-NR807
Post edited by ibewbrother on
    EndersShadow Posts: 17,722
    Check your jumpers, switch speakers. Does it follow the speaker or the amp channel
    Good advice. Tighten up all the terminals so that your jumpers are making full contact with all four points. I had a similar problem when I bought my first set of M-70s. No highs because the jumpers weren't making contact.
    If not check what ES suggests above. And if you have any other speakers, bring those out and check the highs on the amp as well to see if it might be the amp.
    cnh
  • ibewbrother
    Thanks.....will look at the jumpers,,,,The Pioneer should drive some 60s....I have an Adcom I can put on them.....
    Pioneer Elite SC-57
    M70 series 2 mains
    CS2 center
    M40 surround
    M30 front height
    SVS PB 12 NSD
    Brother
    Pushed as hard as the receiver will go ? Like turning the volume dial all the way up ? Then you fried the tweets or the crossover. Why would you push it that hard ?
  • ibewbrother
    Was an expression Tony....as you know there are no stops on any modern receiver.. but for clarity I had it around +1.5/+2.0. According to the meters on my Carvers i was peaking around 200watts in the main zone....steady around 100. And I have no need for a pair of speakers that can't handle 135 watts......
    Pioneer Elite SC-57
    M70 series 2 mains
    CS2 center
    M40 surround
    M30 front height
    SVS PB 12 NSD
