Polk LS70 Woofer distorting
attym
I have a pair of LS70's. They sounds great except recently, I started hearing a slight (you have to listen for it) distortion in one of the woofers. I narrowed it down to the speaker, not one of the sources. It sounded a bit like inner groove distortion on a record. However, if you lightly tap the woofer, it goes away for a bit.
Has anyone experienced this? Is this a repair or is it easier to source a new (MW8100?) woofer?
Thanks!
Thanks!
Post edited by attym on
If you gently push in on the woofer do you feel and "scratchiness"?
ken brydson wrote: »If you gently push in on the woofer do you feel and "scratchiness"?
Yes!
I hear and feel it when I press on it, where the same woofer on the other speaker doesn't do it. -
Yeah, it's shot. Post a WTB thread for one. Seems like a couple members might have some spares.
Thank you... Now to make 10 more post so I can do that.
Getting to 25
No worries, I'm sure I'll source one.
attym did you ever find any replacements for your ls70 if so where, I need 4
