rt12
mp3
mp3 Posts: 1
i have the rt12 floor speakers.I was wondering if any body can tell me what the purpose of the jumper bars are used for.
Post edited by mp3 on
  • mantis
    mantis Posts: 17,570
    edited January 2004
    they are used for when you wire the speakers with a 2 conductor type speaker cable.They are suppost to be remove when you use a 4 conductor speaker wire.
    If you remove them,the bottom driver will not work in a 2 conductor wire hookup,or the tweeter will not work if you wire only to the bottom speaker posts.
    Search on bi wire in here and alot of reading/learning you can find.
    Dan
    Dan
