Onkyo wifi and usb help
snake1
snake1 Posts: 567
edited November 2013 in Electronics
I'm looking to connect my Onk to the wifi in my house with their wifi adapter. The thought that arises is, will anything else work?? Something better? Cheaper? (however $28ish isn't bad).
One other thing, since I have my music HD connected to the rear usb hookup on the Onk, can I get a usb splitter and keep the wifi adapter and the HD on the same rear plug? This is so I can keep things out of sight better. Will this work with both being plugged into the rear? Thoughts??
AVR - Onkyo NR809
500gb HD for MP3 and FLAC files
Amp - Parasound 2250 - FOR SALE BTW!! PM me if interested!
Mains - Polk RTi12 towers
Center - CSi5
Surround - FXiA6's
Sub - psw505
Movies and games - PS3
TV - Toshiba 52" HD
Every vehicle has one good nuetral drop in it
Post edited by snake1 on
  • snake1
    snake1 Posts: 567
    Anyone?
    AVR - Onkyo NR809
    Center - CSi5
    Surround - FXiA6's
    Sub - psw505
    TV - Toshiba 52" HD
  • mantis
    mantis Posts: 17,570
    That might work fine as long as your splitter is of good quality. You can use someone else's WiFi USB adapter but why when the Onkyo isn't expensive?
    Does the 809 have a front USB like the Integra's do?
    Dan
  • snake1
    snake1 Posts: 567
    Just making sure there wasn't a better solution than what they offer. Most things go that way it seems. It does have a front as well, I'd just rather keep everything hidden in the rear if I could.
    AVR - Onkyo NR809
    Center - CSi5
    Surround - FXiA6's
    Sub - psw505
    TV - Toshiba 52" HD
  • PolkieMan
    PolkieMan Posts: 2,446
  • sandworms
    sandworms Posts: 1,043
    http://www.amazon.com/Onkyo-UWF-1-Wireless-LAN-Adapter/dp/B004WR125O/ref=sr_1_1?ie=UTF8&qid=1384016883&sr=8-1&keywords=onkyo+wireless+adapter
    Pretty bad reviews on this one, so I bought this
    http://www.amazon.com/gp/product/B002WBX9C6/ref=cm_cr_asin_lnk
    Found out you can't use the rear usb port for the dongle on my 1010, so it has to plug in the front, I asked people at avs forum and they said the voltage on the rear port isn't compatable with the wi fi dongle? sucks to not be able to close the drop down door or my entertainment center door
    Samsung pn64f8500
    Sonus faber venere 2.5
    Sf venere center
    Oppo 105d
    Squeezebox touch
    Parasound hca1500a
    Apc power filter
    Audioquest cables asst
    Polk rtia3 SB
    Polk fxia6 sl,sr
    Dual hsu vtf3 mk3
  • snake1
    snake1 Posts: 567
    I broke down and called onkyo and they told me to run 2 usb devices on the rear, u have to have a switch because it doesn't know where to send the signal. Just run the wifi adapter on the front port and leave the front plate down all the time.
    AVR - Onkyo NR809
    Center - CSi5
    Surround - FXiA6's
    Sub - psw505
    TV - Toshiba 52" HD
