Cheaper than Granite?
michael_w
michael_w Posts: 2,813
Hey just wondering if there is a slightly cheaper alternative to a granite stand to put under your sub (eg. cinderblock lol). I've looked at these stands and they look good but are just a little out of my price range for now. Is there a different material that does much the same thing?
Thanks for any responses. :D
Post edited by michael_w on
  • gatemplin
    gatemplin Posts: 1,595
    edited January 2004
    Dr. Spec has recommended using air conditioning cement slabs under subs as a cheap alternative.
    Graham
  • dorokusai
    dorokusai Posts: 25,637
    edited January 2004
    Concrete pavers have always been recommended as cheap alternatives.
  • Airplay355
    Airplay355 Posts: 4,298
    edited January 2004
    someone found a steel reinforced concrete slab, home depot or sumthin? slate works too i think but thats expensive still right? check out the garden department somewhere and see if u can find sumthin, u can always cover it in black fabric or spray pant it black
  • Early B.
    Early B. Posts: 7,900
    edited January 2004
    Yep, an 18" x 18" concrete paver at Lowe's for $4 bucks and change. Just spray paint it whatever color you like.
    "God grooves with tubes."
  • Frank Z
    Frank Z Posts: 5,860
    edited January 2004
    I got my granite slab for $10. Head down to your local Marble & Granite yard and ask if you can look through their scraps. You'll be amazed at what you'll find.
  • michael_w
    edited January 2004
    Ok ty for the respsonses. Yeah my dad suggested one of those concrete slabs you put in your garden but I wasn't sure if it would do anything.
    So what do you mean by your local Marble & Granite yard? Like the scraps from a kitchen counter installing business (cause granite counter is kinda expensive)?
  • Frank Z
    edited January 2004
    Check your Yellow Pages under Marble and/or Granite, you'll be surprised at how many you find.
  • mantis
    mantis Posts: 17,632
    edited January 2004
    Ok I get the idea but why do you want ot do it?
    With all the theaters I have setup,I have found the most enjoyable ones have the sub spiked nto the floor so you can feel the sub.the ground transfers the energy to your seating...cool stuff.
    I'm going into construction in the basement for my theater and I want to build a sub floor.I want to raise up the floor using 1x4's and quiet floor.This will get my theater off the concrete floor so the concrete doesn't absorb all the sub bass energy.
    As far as the Marble under the sub,what differences did you guys get?More pressure?I assume so as I haven't tried this.
    Dan
    Dan
  • michael_w
    edited January 2004
    Yes vibrating your chair is cool and "enhances the theater experiance" but since out kitchen is under my room I'd rather not vibrate our kitchen. I'd like to minimize the sound and vibrations outside of my room (plus the bathroom adjacent to my room rattles when I turn it up a bit).
  • michael_w
    edited January 2004
    I thought of another question...... When I get my hunk of rock, should I put feet on it or just leave it footless?
  • Frank Z
    edited January 2004
    Rubber feet on the sub, none on the granite.
  • Airplay355
    edited January 2004
    i didnt know there were local granite yards.....my sub is isolated with one of those lamb skin things that babies crawl on and is upside down so the port could still breathe lol. time for some granite
  • walk
    walk Posts: 178
    edited January 2004
    I made my own :)
    Not bad for my first try? ;)
    - Sony 50"A3000 SXRD; Onkyo TX-SR 805
    - Polk RTi150 mains; CSi30 center; FXi3 surrounds, R15 backs
    - Velodyne CHT-12 subwoofer
