RTA 11TLs vs. PSB T6
87turboT
I am setting up a 2 channel system and was convinced that my 20+ year old RTAs were outdated and I would benefit from modern speakers. Got a good deal on some PSBs and thought they sounded better at the store than my RTAs but after getting them home and trying to convince myself that they sound better I decided to switch back to the RTAs to prove it. Don't know if my ears are just conditioned to the old Polk sound but IMO 20+ year old RTAs were much better. The PSBs have almost the same driver compliment as the RTAs except that they are ported and have a 5.25 mid on top of the two 6.5s. The RTAs seem to play the low bass and bass drums alot cleaner. The mids and highs are sharper and snare drums sound more snappy. I guess old and outdated does not mean inferior or that 20 yrs of technology will automatically make for a better sounding speaker. How will the RDO 198 upgrade change the sound of the RTA 11? Any opinions or theories welcomed. Thank You
Post edited by 87turboT on
The 87 turbo T doesn't happen to be a Buick, is it?
The 198's will be a major improvement. Upgrade the crossovers and you will be amazed at how much better they can be than the ones you bought to replace them. I would take them back, assuming you can, and invest the coin in the upgrades, You can thank me later...
Welcome to Club Polk...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
“When once a Republic is corrupted, there is no possibility of remedying any of the growing evils but by removing the corruption and restoring its lost principles; every other correction is either useless or a new evil.”— Thomas Jefferson -
Hi Nooshin, Yes you are correct about the Buick. 45000 miles and Astro Roof. Cars have been my passion next to HiFi since high school. Also have 68 SS Chevelle L88 427 factory A/C, 69 SS Elcamino 396 4 sp.,85 Elcamino 383 sb, and a 81 Malibu 355. Thanks for the advice on the speaker mods. What kind of upgrades can be done for the xovers? Will try the PSBs with HT set up and see how that goes. Can't return them as it was a CL deal and I need something to replace the 11TLs iin HT setup.
87turboT, are your RTA 11s Ts or TLs? If they're Ts the RDO-194-1 are drop-in replacements for the SL2000s. If they're TLs then the RDO-198-1s are the correct replacements. If they are Ts, not TLs, they can be modified. See the rta11t_rev and rta11tl_rev2 schematics here: http://www.polkaudio.com/forums/showthread.php?38755-POLK-AUDIO-Speaker-Wiring-Schematics-amp-More-ALL-MODELS-except-SDA
If you have basic soldering skills, you can do the crossover upgrade work yourself. If not, Trey/VR3mods, myself, and several other members can do the work for you. There are other modifications that can be done, such as Dynamatting, and gluing the magnet assemblies on the drivers, installing Hurricane Nuts and Machine Screws, or Larry's Rings for all the drivers, repositioning the internal Dacron batting, adding Blackhole 5, Spikes etc.Home Theater/2 Channel:
dhsspeakerservice.com/ -
The T6 certainly aren't as crisp sounding as the Polk, but I find them to have a more natural sound to them, that PSB is still one of my favorite speakers in that price range.
Thanks guys for all the info on the ugrades and mods. Westmass guy, Speakers are TLs with kinda gold tinged tweets. Tag on the back says RTA 11TL. Think I'll try the RDO 198s as it is the least complicated. Does the electronics in a xover go bad over time? How much would the parts and labor cost to freshen up a pair of xovers so it can go another 20 yrs. Is there a post showing pictures of these upgrades as I am new to this but would like to learn how and what can be done. Thanks Again
I am trying the PSBs in a HT set up and they seem to be better suited to this IMO. Seems like the sub rounds it out for my taste. Don't know if the ported design causes lack of impact. They play loud and low but just don't have the punch like the RTA 11TLs. Scored these half price in excelent condition and less than a year old intending to use them for a 2 channel rig but I went back to the Polks.
Thanks guys for all the info on the ugrades and mods. Westmass guy, Speakers are TLs with kinda gold tinged tweets. Tag on the back says RTA 11TL. Think I'll try the RDO 198s as it is the least complicated. Does the electronics in a xover go bad over time? How much would the parts and labor cost to freshen up a pair of xovers so it can go another 20 yrs. Is there a post showing pictures of these upgrades as I am new to this but would like to learn how and what can be done. Thanks AgainHome Theater/2 Channel:
^^^ This - WMG knows what he's talking about. Upgrading the caps and resistors in your Xovers will take those speakers to a much higher level of sound quality.
Welcome to CP!"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
I've got a pair of RTA-11TLs that are currently being used as my front left and right in my HT setup. So far I have been quite impressed with them in this role. They center is a Polk Audio CS245i. I've got a pair of RDO-198s that I will be putting in them sometime this week and giving them a listen.Speakers: TL Monitor 10s, RTA 11TLs, Fortes, Thiel CS 1.2
Amplifiers: ]Ashly FTX 2001 III, Dynaco ST-70, DIY F6
Pre: Adcom GFP 750, Aikido Tube Pre
