Should I bother?
newbie308
I was in a local thrift shop yesterday, and I found a pair of Acoustic Research 2Ax's. They are in rough shape, and would require a lot of work. The price was reasonable enough at $5 for the pair, but after doing some research, the rebuild would approach the $100 mark. I'm just wondering if it would be worth the effort, cost, and time to restore these speakers. The cabinets are scratched and dented, but the drivers appear to be unscathed.
Sources: Technics SL1200MKII | SME3009 Tonearm | Monster Alpha 1 MC cartridge | Oppo UDP203 disk player | Nikko NT-790 analog tuner | Musical Fidelity Trivista 21 DAC | Preamp: Threshold SL-10 | Amplifier: Threshold Stasis 2 | Speakers: Snell Acoustics C/V | Kimber 12-TC bi wire speakers | Analysis plus Oval 1 preamp to amp | Wireworld Eclipse 7 DAC to Preamp | Wireworld eclipse digital IC Oppo to DAC | Audioquest Quartz tuner to preamp |
Post edited by newbie308 on
I was in a local thrift shop yesterday, and I found a pair of Acoustic Research 2Ax's. They are in rough shape, and would require a lot of work. The price was reasonable enough at $5 for the pair, but after doing some research, the rebuild would approach the $100 mark. I'm just wondering if it would be worth the effort, cost, and time to restore these speakers. The cabinets are scratched and dented, but the drivers appear to be unscathed.Home Theater/2 Channel:
dhsspeakerservice.com/ -
The AR2ax is a good sounding loudspeaker but it's not an AR3 nor an AR3a. I'd be hard pressed to turn down a pair for 5 smackers (but, then again, my pair was a dump find). They have reasonable resale value and they do sound good but they're likely to be kind of 'relaxed' sounding to modern ears.
They were in production for many years so there are several variants of the woofers AR used. I think later ones used foam surrounds; the earlier ones didn't.
1966 ARs by mhardy6647, on Flickr -
I went to purchase a receiver once. Walked in & was blown away by the sweet sound coming from a beat up pair of speakers. Dont let looks fool ya-your ears dont care how they look-just the wife/husband does. If they work good cosmetics can be relatively reasonable.if your on a budget search..
Most likely, they would be used in my garage rig or in my gun room, so I guess the cabinet condition is less of an issue for me. I was considering a rebuild for resale, in which case appearances are critical to most interested consumers. Especially since I would want an ROI+. That puts them in the $140 range where there will be a lot of competition. To top it off, I truly do not need another set of speakers!Sources: Technics SL1200MKII | SME3009 Tonearm | Monster Alpha 1 MC cartridge | Oppo UDP203 disk player | Nikko NT-790 analog tuner | Musical Fidelity Trivista 21 DAC | Preamp: Threshold SL-10 | Amplifier: Threshold Stasis 2 | Speakers: Snell Acoustics C/V | Kimber 12-TC bi wire speakers | Analysis plus Oval 1 preamp to amp | Wireworld Eclipse 7 DAC to Preamp | Wireworld eclipse digital IC Oppo to DAC | Audioquest Quartz tuner to preamp |
If they're shot, part out the working components and help keep other speakers alive. You'll turn a profit and make people happy.
Yep....be an organ....I mean driver donor! lol--Gary--
I owned - for quite a few years - the world's ugliest pair of AR-3 loudspeakers. They sounded just fine though. Just fine.
(from my favorite local emporium, of course... one of my first loudspeaker finds there, actually... twenty-ish years ago)
EDIT:If they're shot, part out the working components and help keep other speakers alive. You'll turn a profit and make people happy.
actually, this is very good advice. One needn't feel ghoulish in enabling other speaker reanimators... -
At least in the DC area, good AR2AXs have quite a following and will sell well. I had a beat-up pair which I sold on for $150 after having them on CL for less than 2 hours, and that was with non-operable tweeters!
As for a simple revamp project, there are lots of other speakers which are much simpler to restore. The ARs used a putty to seal the drivers into the cabinets, making them a real pain to get out. The grilles are also glued to the cabs, meaning removal, if not done carefully, could break the grille frame or mar the finish on the cabinets.
The potentiometers on the back of the speakers corrode horribly, killing sound to the drivers. They need to be lubricated and cleaned at the least. In many cases they are unsalvagable, meaning you have to reverse-engineer a new solution using new l-pads or setting appropriate fixed resistance using new resistors.
Add all these landmines to the issues noted above with voice coils and cones.
Unless you're really interested in learning to how restore these speakers, I would wait for a nice pair of KLHs to come by. They sound very similar (good!) and are very easy to work on. And the components are way cheaper.
Good luck either way!
GHT System:
Marantz NR-1403
Front: Klipsch CF-4
Rear: Paradigm Atom V3
Center: Boston Acoustic VR12
Sub: Bowers & Wilkins ASW600
2Ch:
Restored Fisher 500C
Yamaha P-500 Turntable
Living Room:
Harman Kardon 3380
Restored Polk Monitor 7B
Bedroom:
Harman Kardon VR-3750
Cambridge Soundworks Ensemble
Polk PSW10
In and out of rotation:
KLH Model 6,
Polk LSI7
NAD 7100
