My 2 Channel Project
boston1450
Picked this up Concord cr200 was gonna sell it. But it sounds great with 5jr+ & i got 0.00 into it. Cleaned up nicely. Im going to do inside 1st -light sand on w/box top & stain it. I need 2 small knobs (ebay/cp member) then it should go another 20 years. NOT SURE but online i read product of Epicure- seems to be built nicely- i know value is nothing. But unique to say the least. ? Any good places to get knobs ? TIAAttachment not found.
Post edited by boston1450 on
Attachment not found.someone wrote on top with black marker & light stains but no scratches..
Attachment not found.I messed up on last post. There is a gough in back which gives it zest-will need 2 small knobs.dont have to match these..
Thanks Rick.. its going in garage.with other speakers for winter . I got a Ym cr620 thats coming down with a cold..
Looks great Randy!
Those markings may come of with Mr. Clean's Magic eraser. I've used them to get Kool Aid red stains off a wood kitchen table. Try it in a small area. You may need some Watco refinishing oil with a little stain to fix it. Try the oil first, then a light dab of stain.
Our resident refinishing expert F1Nut will probably give you professional advice. His advice has never failed me. Good luck!Carl -
Nice old piece. Since you said the knobs don't have to match, perhaps there is something here you can use?
http://www.electronicsurplus.com/LeftNav/Hardware/Knobs.cat
Nice Find Randy.Home Theater/2 Channel:
dhsspeakerservice.com/ -
Thanks great suggestions ill try them.glad they didnt use a pen..
