Clean the tweets OR leave them alone ?
boston1450
boston1450 Posts: 7,671
edited October 2013 in Vintage Speakers
These look brittle but sound very nice. Should i use windex with a Qtip & lightly clean it OR leave it alone ? TIAAttachment not found.
Post edited by boston1450 on
  • zane77
    zane77 Posts: 1,696
    edited October 2013
    Personally I'd leave the way they are
    Two Channel
  • boston1450
    edited October 2013
    Well thats what i thought. It looks like dust up close.its just a coupe years old i guess ;) Thanks
  • westmassguy
    westmassguy Posts: 6,850
    edited October 2013
    It's treated cloth, very doubtful Windex, Fantastic, or 409 with a Q-Tip will hurt the dome or the doping they used. I cleaned quite a few that way. The metal bezel can be cleaned with a soft cloth. I've even painted quite a number of Peerless tweeters. I found a prescription bottle cap that fits perfectly in the small grove where the dome attaches to the bezel. Hold the cap in place with a pencil, or rod, then shoot some satin/flat Krylon. They'll look nearly new afterwards.
    I'm sure you know how to clean the woofers properly by now.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • boston1450
    edited October 2013
    Yes i have :) all my others are SL's & the method works well.
