What's needed to drive SDA's
Easy Runnin
Easy Runnin Posts: 501
edited October 2013 in Vintage Speakers
Sooner or later I'm going to get a pair of SDAs. What's need to drive them. At this point I have a NAD 2400 which is 100wpc. Is this sufficient power? I would think this would work for some models.. Could someone tell me which models will work with this amp?
HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
Rt35i Surrounds/Cs1000p Center/SVS BP1000 Sub
2CH - B&K MC-101 pre/B&K EX-442 amp/NAD 2400 amp
Polk SDA1C, Polk Monitor 7, New Large Advents and Polk RTA 8T
BR - Yamaha CR800/Polk monitor 5
Post edited by Easy Runnin on
  • PolkieMan
    PolkieMan Posts: 2,446
    edited October 2013
    I run SDA 1C with that much power but I don't play them real loud 14x16 room.
  • oldrocker
    oldrocker Posts: 2,590
    edited October 2013
    Running a parasound 2250 with 2100 pre, sounds good to me cept the SDA's need some mods.
  • nhhiep
    nhhiep Posts: 877
    edited October 2013
    100 real Watts from NAD is good, but depending on how loud you're playing. 3db = 2x power. I am super happy with my 130 WPC HK Citation 7.1 amp for my 1Cs.
    F1nut Posts: 50,748
    edited October 2013
    It'll work with any SDA model. Will you get out of them what they are capable of? No effing way.
  • westmassguy
    westmassguy Posts: 6,850
    edited October 2013
    This^^^^^^^^^
    If you stick with the later, unmodified 2 driver models like the CRS+ or 2Bs which are 6 ohm nominal, you should be OK at moderate levels. If you have a lead foot on the volume control, are using any of the earlier 4 ohm models, or later models with multiple drivers, It won't be pretty.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • leftwinger57
    leftwinger57 Posts: 2,917
    edited October 2013
    Most around here say do not atepmt to run them through a stand alone avr at all , but if you have an avr w/ preouts or are going w/ seperates go w/ 200 wpc a side and you will have more than enough juice to make them come alive. Adcoms are all over the place as are B&K, Bryston and many ,many other stand alone power amps on the used market.
  • dcoil
    dcoil Posts: 153
    edited October 2013
    I was running a late model Yahama AVR w/ 120W/channel. My SRS's sounded really, really good. And let me say I think the Yamaha is very musical - absolutley killed the AVR it replaced of same power. Then I got separates - Pass pre-amp and a Parasound amp (high current and 200w/ch). Well, this killed the Yamy....
    SDA SRS modded: X’ovrd, de-polyed, inductorized, interconnectorized, re-posted, dynamited, RDO’d, spiked, gasketed, ringed (Larry's), and grill cloth blinged! Done this on my own? Not a chance. Thanks to Raife and all who forged easy to follow upgrades. At least a 100% improvement in sound and my personal listening pleasure! :cheesygrin:Pass XP-10 preamp, Parasound A21 amp, Pioneer Elite DV-58AV (Ric Shultz modded), Audioquest Sky IC's, No longer need my Sunfire sub after mods...
  • drumminman
    drumminman Posts: 3,396
    edited October 2013
    Lots of clean high current power allows any speakers to play louder, but also provides a level of clarity at lower volumes that low powered amps can't duplicate. F1 stated it pretty well.
    Buy as much power as you can afford. I would consider 200 wpc minimum. As Tim the Toolman Taylor used to say, "More Power" :cool:
