RTA12B mid-range took a dump
laotzu61
laotzu61 Posts: 327
edited September 2013 in Vintage Speakers
I hope i'm posting this in the right place. anyway, about a week ago, the left-hand, mid-range in the right channel
speaker took a dump. It may have happened due to a voltage surge during a storm. in any event, it is now very
scratchy, and sounds terrible. my question is; am I better off removing the speaker via the front screws and
disconnecting it until I find a replacement? also, what is a good source for a replacement? this really sucks---.
thanks for any help.
"The symbol is not the reality"
Post edited by laotzu61 on
  • rmaiers
    rmaiers Posts: 145
    You can get a new replacement from Polk for $48.00 or you can find used ones on ebay or in the for sale section here. I have had to replace 3 mid-range drivers on my RTA-12Bs.
  • laotzu61
    laotzu61 Posts: 327
    thanks for the info. i'll probably get a replacement from polk to be safe. is it okay to just disconnect the current one
    in the interim and use the speakers without till I get a new one?
  • soundfreak1
    soundfreak1 Posts: 3,414
    What driver # is it as if mx6600 there are some jere available .
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • laotzu61
    laotzu61 Posts: 327
    soundfreak1; I wouldn't know unless I take it out; would I? that's 1 reason i'm asking if that's ok at this point. also, I would think the speaker would sound better without the scratchy mid-range, but I don't know. thanks.
    pitdogg2 Posts: 25,683
    Take it out and get the number off it. If it were mine I would not play while the broken woofer is out. Better safe than sorry.
    Sounds to me that a magnet slipped. I would go ahead and JB Weld all the rest of my drivers magnets while I'm waiting and have these apart.
  • laotzu61
    laotzu61 Posts: 327
    pittdog2; it's not the woofer--it's the left midrange in the right channel speaker. if it's not ok to remove it, i'd just as soon leave
    it in till I get a replacement. can't live without the music however scratchy
  • Nightfall
    Nightfall Posts: 10,086
    laotzu61 wrote: »
    They're one in the same.
    Unscrew the midwoofer, make not of which color is positive and which is ground, disconnect the woofer, get the model number off the back probably mw6600, screw the woofer back in while still disconnected so that you can still play the speakers, order a replacement.
    Edit: Use electric tape or some other form of making sure the dangling wires that were once on the woofer don't touch each other.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • laotzu61
    laotzu61 Posts: 327
    Nightfall wrote: »
    thank you, nightfall. i'm on it. will I be dealing with solder connections, or some sort of plug-ins? thanks again.
  • Nightfall
    No, they just pull on and off. Note my edit in post #8.
    afterburnt wrote: »
  • Nightfall
    Also, the two different woofers are rolled off at different frequencies so they might sound... off, until you replace the broken one.
    afterburnt wrote: »
    laotzu61 wrote: »
    only you can answer that. that is why we keep telling you to open it up and look.
    1. some early models were soldered later they used fast on's
    2. they used different woofers back in the day Nightfall and I know this it will either be mw6600 or maybe 6500 and it very well could be 6501.
    3. real early models may of used different woofers for each woofer i.e. 6600 on left and 6500 on right as they were left and right speakers so the outer woofers were the bass and the inner were the mid range.
  • laotzu61
    laotzu61 Posts: 327
    thanks, guys. I really appreciate the help. get back to ya later.
  • drumminman
    drumminman Posts: 3,396
    I have RTA 12C's, and mine use MW6600X mw's; I suspect yours do too. What are you driving these with? Might want to do a little detective work to prevent this from happening in the future.
    I bought mine new in 1984, and have never replaced anything out of necessity. Now mods, that's another story . . .
    EndersShadow Posts: 17,596
    laotzu61 wrote: »
    Someone here recently was selling some woofers for the 12's IIRC...
    Boom, here we go: http://www.polkaudio.com/forums/showthread.php?148389-Pair-%282%29-Polk-Audio-MW-6600X-drivers-for-RTA-SDA-Monitor-10Bs
  • laotzu61
    laotzu61 Posts: 327
    drumminman wrote: »
    parasound hca-1200, which I suspect may have taked somewhat of a hit during the storm also.
  • laotzu61
    laotzu61 Posts: 327
    well, it's an mw6600x; 1 blue wire and 1 white wire. not sure which is considered positive and which negative, but they are
    soldered connections and it appears as tho the white may be bad. don't see any cracks in the speaker. wondering if I should clip
    both until I can fix it and put the speaker back in, or just leave as is until I can repair the solder connection if that's it, or until
    I just replace the speaker
    laotzu61 wrote: »
    blue is positive white neutral. you could crimp on some fast on's but you'd need to get all solder off tabs first. That would be my route. Push in on woofer do you feel scratchy? If yes it's not long for this world unless you can adjust the magnet, but that does not sound like the problem as you stated. I WOULD however JB weld all driver magnets and Dynamat extreme the baskets while you're in there.
  • laotzu61
    laotzu61 Posts: 327
    so, here is what I've done. pulled the speaker out; it's not cracked, but the solder joint to the white wire looks pretty bad at best. put it back in and it sounded worse. may have pulled on the wire to much. took it back out, clipped the 2 wires and taped them and marked them, and now they're hanging. put the speaker back in and now I have to adjust the balance to the left channel to compensate, which sounds goofy, but whatever. physics, I guess. remember this all started after a very bad thunderstorm in which I should have turned everything off, but didn't, like a dummy, thinking the surge protector would do it's job. subsequently also, when I adjust the line level knobs on the parasound, the standby led cuts in, which it never did before. according to the manual, "this red led will come on whenever you first turn the unit on. it will light for 4 to 5 seconds while the circuit is stabilizing before the protection relays click on. it will also light up whenever there is a short circuit or fault which triggers the protection relays." so---what am I looking at now as far as the parasound? not sure I want to know.
  • drumminman
    Have you looked at the Xover(s) to see if any of those components are fried? Remember there's a lower one as well as one on top.
    BTW, I've never heard of Polk soldering wires to speakers. All the Polks I've seen us the quick connect push on connectors. Wonder if some previous owner has done some work on those.
  • laotzu61
    laotzu61 Posts: 327
    i'll look at the crossovers tomorrow. wouldn't the fuse protect them? as far as the soldering, looking at the job that was done, you're probably right about a previous repair.
  • laotzu61
    laotzu61 Posts: 327
    drumminman wrote: »
    BTW, I've never heard of Polk soldering wires to speakers. All the Polks I've seen us the quick connect push on connectors. Wonder if some previous owner has done some work on those.[/QUOTE
    now that the speaker wires are disconnected, can I get the quick connect push on connectors from polk or wherever and crimp those on?
    drumminman wrote: »
    Polk did solder some of the older speakers I've seen Monitor10's & 7's soldered
  • laotzu61
    laotzu61 Posts: 327
    thanks, pitdogg2. can I crimp on some quick connect push on connectors now that the 2 wires are clipped off? where would I get some? thanks again.
    laotzu61 wrote: »
    I buy mine at auto supply store. i.e. autozone, advanced auto.
    I buy the gold plated you'll also need a crimper wire stripper to go with it to crimp properly.
  • laotzu61
    laotzu61 Posts: 327
    pitdogg2; is there a specific size I need to ask for? thanks very much.
  • laotzu61
    laotzu61 Posts: 327
    I have yet another question now. took the top-hats off, and I can't hear anything coming specifically out of the tweeters. fuses are good. is this normal??
  • Nightfall
    laotzu61 wrote: »
    Yikes, not at all. Try wiring the tweeters, one at a time, directly to the speaker taps on the back of your amp at a very low volume. If you have tone controls of any kind turn the bass to -(as far as it goes). Any sound?
    afterburnt wrote: »
  • Schurkey
    Schurkey Posts: 2,104
    How does a lightning strike fry a speaker? I don't get how the surge goes through the transformer, rectifier, through the power transistors, and into the speaker crossover..
  • laotzu61
    laotzu61 Posts: 327
    anyone know what amp fuses are used in the crossovers? I have the rta12b specs and can't find anything regarding this. also, schurkey, i'm starting to lean towards a bad solder connection. then again, why would that come into play only after the thunderstorm? btw, we now have another bad one coming thru, and I have everything disconnected this time. last one also blew out the uverse tv and internet and the techs had to come in.
  • drumminman
    laotzu61 wrote: »
    3/4 amp fast blo. It's on the schematic for the RTA 12b (orig); it's also what my 12C's came with.
