Recommendations? Need center for Monitor 12's
jrdorst
jrdorst Posts: 3
edited September 2013 in Vintage Speakers
Hi. I have been a happy owner of Monitor 12's since the early 80's. Currently they reside in the entertainment room mostly used to provide the audio for movies. They sound great, even after all these years.
I'm wondering if anyone has a suggestion for the best center channel speaker to accompany them. I expect that we will stick with a 2.1 system. I've read that the center is very useful for movies, etc. as it's the primary sound source for much of the presentation.
If you have any questions that may help you with your answer, please ask away.
John Dorst
Post edited by jrdorst on
  • boston1450
    boston1450 Posts: 7,671
    WELCOME to CLUB POLK....just a thought. How about a Monitor 5 or Monitor 7 for timbre match. Sure others will chime in
  • halo71
    halo71 Posts: 4,606
    Welcome aboard! I really have no recommendations other than a Monitor 7 or 10. But then again it would be a shame to split one up for just a center channel. If you were running 6.1 it would be another story though.
    --Gary--
  • Nightfall
    Nightfall Posts: 10,086
    halo71 wrote: »
    Why split them up? :wink:
    afterburnt wrote: »
    Village Idiot of Club Polk
  • halo71
    halo71 Posts: 4,606
    ^ I take back what I said! Nice setup there....
    --Gary--
  • jrdorst
    jrdorst Posts: 3
    Nightfall wrote: »
    So - did you just connect both of them to the center channel?
    Or has anyone tried any of the center channel speakers that Polk has on the market now? Or are they enough different that they'd be difficult to listen to?
  • Nightfall
    jrdorst wrote: »
    Yes. You can either wire them in parallel, doubling the impedance, or you can wire them in series, halving the impedance.
    If you're against using vintage monitors as a center, it's a general consensus that the CS400 or CS400i are a decent timber match to vintage Polks.
    afterburnt wrote: »
  • jrdorst
    jrdorst Posts: 3
    Nightfall wrote: »
    Thanks for the info. Not necessarily against using them - it does seem a bit excessive, though as they are amazing speakers. It's mostly a space consideration. Thanks for the recommendation of the CS400 or CS400i. I'll take a listen to them.
  • Msabot1
    Msabot1 Posts: 2,098
    Hey....you will get a lot of useful info here...I have been using a CSIA4 center and am quite happy with the performance! Look it up on the Polk Audio site...will run ya the specs and give ya visuals of the finishes ect!
  • zingo
    zingo Posts: 11,258
    How about a Monitor 5Jr? They are small, but use the same drivers, so should be a perfect match similar to the Monitor 7s posted above.
  • StantonZ
    StantonZ Posts: 445
    I run a pair of Monitor 4's as a center channel in my surround sound setup of Monitor 10's. The reason for my post is if you want to get an (old) amp/receiver that is specifically designed to handle "parallel" centers (it sounds as though you don't yet have a surround sound amp), look for an old Yamaha DSP 3090 (DD only) or A1 (adds DTS): I've used both with great results (see my sig).
    (2) Polk RC80i (Top Middle)
    Polk CS300 center channel
  • ken brydson
    ken brydson Posts: 8,783
    jrdorst wrote: »
    CS350LS is a decent match as well.
  • Mystery
    Mystery Posts: 2,546
    jrdorst wrote: »
    Nightfall wrote: »
    It'll be awfully difficult to have a pair of 10's as center channel just because of their size and weight.
    I won't go over 5's if using a pair on the TV stand.
    If you can use them on the floor with TV mounted on the wall, then no problem but a pair of 10's as center is overkill.
  • westmassguy
    westmassguy Posts: 6,850
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • gmjungbluth
    gmjungbluth Posts: 232
    I used a recapped Series II Monitor 5JR as a center and was quite happy.
    HT System:
    Marantz NR-1403
    Front: Klipsch CF-4
    Rear: Paradigm Atom V3
    Center: Boston Acoustic VR12
    Sub: Bowers & Wilkins ASW600
    2Ch:
    Restored Fisher 500C
    Yamaha P-500 Turntable
    Living Room:
    Harman Kardon 3380
    Restored Polk Monitor 7B
    Bedroom:
    Harman Kardon VR-3750
    Cambridge Soundworks Ensemble
    Polk PSW10
    In and out of rotation:
    KLH Model 6,
    Polk LSI7
    NAD 7100
