Rt3000 sub buzz
dbartol1
dbartol1 Posts: 46
edited February 2014 in Troubleshooting
Hello, i have a 2 pairs of rt3000 speakers. One of the four has a soft buzz coming from the lower section ( the bass unit/amp). I have swapped out the lower portions between outlets and speaker wires and the buzz follows the one bass/amp. The speaker overall seems to work fine. Powerful bass and nice sound. Thoughts? Fixes?
Thanks!
Darrin
Post edited by dbartol1 on
  • dbartol1
    dbartol1 Posts: 46
    edited September 2013
    I didnt check but will look at those. Are they easy to replace? Expensive?
  • dbartol1
    dbartol1 Posts: 46
    I checked the two big caps. Both had mild bulging and one had some corrosion, looked like rust.
  • dpowell
    dpowell Posts: 3,081
    DSkip wrote: »
    They need to be replaced. I could only find Panasonic versions of them and they were about $10 per + shipping. I can't remember where I got them, but they are 15,000 uF IIRC.
    +1, yep your caps are bad. Same thing happened to mine several years back. I called Polk customer service and they shipped me out replacement caps. Tell them you're a club polk member for a discount.
  • sandmanal
    sandmanal Posts: 16
    I have the same problem and took it in to get looked at and the coil is shot.
  • WLDock
    WLDock Posts: 3,073
    sandmanal wrote: »
    What was ba on yours? An inductor?
  • sandmanal
    sandmanal Posts: 16
    They told me the voice coil was cooked it would have to be recoiled.
  • sandmanal
    sandmanal Posts: 16
    It does the same thing you described low level buzz / distortion but sounds good at higher levels and bass still hits great. With the speaker on take off cover and push on foam or speaker and you will really hear it or at least that's what mine does.
  • sandmanal
    sandmanal Posts: 16
  • WLDock
    WLDock Posts: 3,073
    You guys should buy any replacements you can find. There is a guy on eBay that is trying to sell just the sub towers locally. I emailed him and mentioned that if he does not get any bids that he might be able to get more money by selling the unit in pieces if his prices are not crazy.
    Anyway, I have no idea how long I plan to keep mine but I started to look around for a driver that had similar parameters. The parameters are posted on Vr3 mods: http://www.vr3mods.com/LCRT3000PTS.html I was suprised when I ran accross an old friend in the Peerless SLS 830667 driver. I played with these awhile back, was going to build a 3-way front stage in my car with these as dedicated midbasses. Anyway, they make great midbasses and by looking at the specs(Low Le numbers, etc) compared to the Polks, I can see why many like the tighness of both these drivers for lower midbass/upper sub bass. As far the latter, will have to play with the port as well as deal with the Ohm difference but....if mine go bad and I can't find replacements, I might give the SLS drivers a try.
  • dbartol1
    dbartol1 Posts: 46
    edited October 2013
  • dbartol1
    dbartol1 Posts: 46
    edited November 2013
    Here is how I made out:
    I called Polk to try and order a pair of capacitors for the RT3000 amp. I was told they will not sell individual components for the amp. They suggested Parts Express, but PE did not have any. So I located a company online called Tedss.com. $10 each + shipping. Arrived within a couple days. After researching how to solder on YouTube I removed the old capacitors and put the new ones in. Put everything back together and doubled checked my work against the pictures I took. I held my breath, plugged her in, and to my amazement...it worked perfectly. No more buzz. Thanks all. I wouldn't have known about this problem without your help.
    P.S. - For anyone planning on doing this, one thing that I wasn't aware of that tripped me up briefly was the old caps have a small amount of glue/paste holding them to the circuit board in addition to the solder. I used a VERY small flathead screwdriver to pry the cap off after removing the solder. Good luck and take pictures before starting.
  • TroyD
    TroyD Posts: 13,124
    Did PE have a replacement for your remote??
    (a few of the old timers will get a chuckle out of that)
    Paging, George Grand! Lunatic on line 1! Mr. Grand! Lunatic on line 1!
    BDT
  • WLDock
    WLDock Posts: 3,073
    dbartol1 wrote: »
    Nice price for a local product...and they are 105 degree temp rated and Panasonic....better than what you removed.
    Nice Work!
  • dbartol1
    dbartol1 Posts: 46
    Hey Troy. Hope all's well with u and George. I stopped looking for the remote long ago, but often find myself thinking about it. Me and that 'mote had some good times.
  • thomaspeople
    thomaspeople Posts: 2
    I am looking to do the same repair on my rt3000p subs and was able to locate a Panasonic 15000uf capacitor on the website that was recommended (tedss.com). It is part # ECEC1KA152CA. Is this the one you used dbartol1? Also, I noticed the the factory capacitors are 63 Volt and these are 80 Volt. Will this cause a problem?
  • WLDock
    WLDock Posts: 3,073
    No, thats a 1,500 μF. You need a 15,000 μF 63V , snap in. These will work:
    http://tedss.com/2020030841 (Panasonic - $10)
    http://tedss.com/2020031421 (Panasonic - $10
    http://tedss.com/2020021309 (Aero-M / Min order 3, but $3.50 each)
  • thomaspeople
    Thanks for catching that! I would like to hope that I would notice before I bought them but I'm glad I asked.
  • Pardon me for jumping onto this thread.
    I have a Polk RT3000p subwoofer that now has a loud buzzing sound after the power went out the other night. The amp still drives the subs. Based on the advise above, I'm planning to replace the caps. Are there any other parts I should be replacing while I have the unit apart? I looked at the caps, and I don't see them bulging as described above, so I'm curious if it could be something else. Thanks in advance.
  • WLDock
    WLDock Posts: 3,073
    edited December 2014
    These units were made back in 98-04 and the caps have been known to go bad with age. I bet the surge did not help the situation. Its time to replace them as they are mostly likely the source of the noise. Replacing the caps in mine (as well as many others)cleaned up all the noise and issues I was having.
    I would pull the amps apart before you make your order and do a visual of all the components. Look for burnt resistors, etc. If everything looks OK just replace the caps. Should be good for ten more years! :)
