SDA 2 ????? misinformation on polk site or??
Bacchus
hello...
there seems to be some inaccuracy on the product specifications for the SDA 2's on the polk site....
http://www.polkaudio.com/products/sda2a
This shows the SDA 2a as having two tweeters and is pictured as only one??
also the sda 2b is pictured as having only one tweeter and two mids and is listed in specs as having three tweeters....?
I am trying to identify my Sda 2's..... one tweeter, two mids and a blade / blade connection.... anyone have the answer on this one?
Post edited by Bacchus on
You have the 2b's...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
“When once a Republic is corrupted, there is no possibility of remedying any of the growing evils but by removing the corruption and restoring its lost principles; every other correction is either useless or a new evil.”— Thomas Jefferson -
this would imply that 2a's have two tweeters then?
You have SDA-2As, if they have blade/blade connector, wood grained vinyl all around, single SL2000 tweeter, and 2 MW6510 woofers.Home Theater/2 Channel:
dhsspeakerservice.com/ -
ok.... um we seem to have a contradiction here.... does this then mean 2bs have two tweeters?
I had the same problem w/ that site ,then when described and then shown in pictures I was informed that mine are 2bs.As you know there is no designaton on the backs.After slightly modding w/ Dyamat and floor deadener I saw they were built in 87'2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
ok.... um we seem to have a contradiction here.... does this then mean 2bs have two tweeters?Home Theater/2 Channel:
The speaker configuration is the same as mine but the cabinet seems to be different... mine look like these ones
http://i210.photobucket.com/albums/bb316/kwkeen/POLKAUDIOSDA2SPEAKERS.jpg
Can I consider these confirms as sda 2a ? -
http://i210.photobucket.com/albums/bb316/kwkeen/POLKAUDIOSDA2SPEAKERS.jpgHome Theater/2 Channel:
thanks for confirming... do you know what the ohm rating is ??? 4 or 6 ohms?? if you have a link to the specification for the 2a that would be great
thanks for confirming... do you know what the ohm rating is ??? 4 or 6 ohms?? if you have a link to the specification for the 2a that would be greatHome Theater/2 Channel:
