Quick, ready to pull the trigger.
Nightfall
http://www.ebay.com/itm/POLK-AUDIO-MONITOR-5-SW-80-PASSIVE-RADIATOR-/310703274192?pt=US_Speaker_Parts_Components&hash=item48575bb8d0
Do all Monitor 5's have the same PR? Not counting JR's, but all regular Monitor 5's. I believe I have 5A's as they are Peerless and am ready to buy the linked PR, just want to make sure I have the correct one.
afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk
Post edited by Nightfall on
I don't see any spec mentioning the PR.
However, all following versions of 5 below have 6502 mid driver as per schematics so PR may be the same.
Monitor 5B
Monitor 5B
Monitor 5jr
Monitor 5jr+
Monitor 5B
Monitor 5B
Monitor 5jr
Monitor 5jr+Home Theater/2 Channel:
dhsspeakerservice.com/ -
Do all Monitor 5's have the same PR? Not counting JR's, but all regular Monitor 5's. I believe I have 5A's as they are Peerless and am ready to buy the linked PR, just want to make sure I have the correct one.Home Theater/2 Channel:
My 5A Peerless also have the MW6500s in them. Not sure about differences in the 8" Passive driver, but all full sized 5s did have an 8" that, at least, looked similar from the front?
cnhHome Theater/2 Channel:
Well it's too late, I ordered it last night. If my scale goes high enough I will compare weight. Might as well pull the one I have and see. Yes, MW's are 6500.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
Well it's too late, I ordered it last night. If my scale goes high enough I will compare weight. Might as well pull the one I have and see. Yes, MW's are 6500.Home Theater/2 Channel:
The one I have now weighs 318.3 grams. Want to weigh one of your 5B PR's?
Now that I pull it out and look at the back, it looks the same as the one I bought? I guess I'll find out Friday or Saturday.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Any writing on it?Home Theater/2 Channel:
Only what appears to be somebodies initials. No dates or model numbers.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
I see a single difference between the two. The ripped up one I have now has 8 notches cut out of the front rim where screws would go even though only 4 screws hold it in. The one I'm buying only has 4 notches. They both have what looks to be the same foam as a seal between the cabinet. They both have the same size "puck" in the middle of the PR, I suppose that doesn't automatically mean they are the same weight though.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
I see a single difference between the two. The ripped up one I have now has 8 notches cut out of the front rim where screws would go even though only 4 screws hold it in. The one I'm buying only has 4 notches. They both have what looks to be the same foam as a seal between the cabinet. They both have the same size "puck" in the middle of the PR, I suppose that doesn't automatically mean they are the same weight though.Home Theater/2 Channel:
These appear to be made from a cardboard type material where the PR's on my RTA12s are made from styrofoam.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Sometimes we'll never know what secret sauce the used back then to tune themHome Theater/2 Channel:
Something else I have noticed is that whenever I see a picture of the inside of some modded speakers around here they aren't packed full of this white foam material that mine are.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Something else I have noticed is that whenever I see a picture of the inside of some modded speakers around here they aren't packed full of this white foam material that mine are.Home Theater/2 Channel:
I remember someone on this site asking me to check this material when I was replacing an inappropriate driver in one of my 5As (6502) with the correct 6500. He had a set of 5Bs and asked me if my padding ran the entire distance down to the PR. His did NOT have padding behind the passive, evidently, and mine did. It sounds like yours does too. So what does that DO to the "fine" tuning of a PR, I wonder?
Dacron Batting. The cabinet is full of it. There is a rolled up section of it on the bottom of the cabinet and another unrolled section of it taking up space in the top. The only place in the cabinet that doesn't have it is in front of the crossover between it and the PR.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Dacron Batting. The cabinet is full of it. There is a rolled up section of it on the bottom of the cabinet and another unrolled section of it taking up space in the top. The only place in the cabinet that doesn't have it is in front of the crossover between it and the PR.Home Theater/2 Channel:
I do believe there may be some variation on how the batting fits in different model 5s? But I would wait on the old timers to confirm this. Mine do not show any difference between the two; the batting is fairly evenly distributed behind the PR. And it does not seem like it fell or to be the result of a mistake.
But who knows! We all know various Polk runs were not ALWAYS uniform. And that there is a lot of variation and some unexpected surprises.
That looks pretty much like my 5As do in there. So you have to wonder if that's not the standard for those? It also seems unlikely that the batting fell from anywhere above.
The current thinking for all the vintage Monitors and SDAs, is the batting should only be in the upper portion, behind the woofers and tweeters. The lower section, which includes the PR should be free of any batting. This allows the PR to operate freely. I've done all my Polks this way.Home Theater/2 Channel:
Another quick question. Is there anything I can apply to all the rubber surrounds to keep them healthy and "hydrated" so they don't end up like the PR I am replacing? I have 11 other MW's and PR's that I'd rather not replace for this same reason in my setup.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Another quick question. Is there anything I can apply to all the rubber surrounds to keep them healthy and "hydrated" so they don't end up like the PR I am replacing? I have 11 other MW's and PR's that I'd rather not replace for this same reason in my setup.Home Theater/2 Channel:
So it is likely that one day I will be running the Chinese made replacements? Bummer. Polk doesn't make PR replacements though, so what will happen with that?afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
So it is likely that one day I will be running the Chinese made replacements? Bummer. Polk doesn't make PR replacements though, so what will happen with that?Home Theater/2 Channel:
Well, they're a little different. The material the cone part is made of on the replacement is smoother compared to the old one which has a very bumpy texture to it. Weight is a little different too.
Old - 318 grams
Replacement - 303 grams
Not sure if 15 grams is enough to actually hear a difference or not, that is not much weight. At least the cabinet is sealed now, though. Dates are different too. I forget the actual date, but the MW6500's I think were 1983 so I assume the PR is the same year. The replacement is dated 1989.
Maybe I will just try and find another 1989 Monitor 5 PR so that even if it does change the bass a bit, they will both be the same.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Something else I thought of is there is no way I can tell if the weight lost is from the cone and puck or if it's from the basket as I'm weighing the entire PR. If it's lost in the basket then I'd guess they both sound the same?afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Something else I thought of is there is no way I can tell if the weight lost is from the cone and puck or if it's from the basket as I'm weighing the entire PR. If it's lost in the basket then I'd guess they both sound the same?Home Theater/2 Channel:
