DSWMicroPRO2000 won't power on....
maverik259
maverik259 Posts: 4
edited September 2013 in Troubleshooting
I've tested the power cable and its pushing 120v, I've pulled the fuse that's right there at the power inlet and it looks perfect and shows a resistance (although it was constantly changing).
Is there anything else i can test?
Post edited by maverik259 on
    F1nut Posts: 52,159
    edited August 2013
    Give Polk Customer Service a call.
  • maverik259
    maverik259 Posts: 4
    edited August 2013
    ya I was hoping to do something local, but it seems there aren't any home audio repair shops in the ventura area! FML
  • specd_out
    specd_out Posts: 504
    My 4000 was not powering on but it was disintegrating fuses. called polk and they said that the amp needed to be replaced, with a cost of $640. I bought a crown xls1000 and a art cleanbox pro to power the speaker. Sounds amazing now. Cost me just under$ 300 for all of it
    HT Rig Samsung 64F8500 |Pioneer Elite BDP-52FD|Pioneer Elite VSX-32| Two Carver TFM-15cb Bridged for mains|Polk Audio RTiA5 Cherry|Polk Audio CsiA6 Cherry|Polk Audio T-15 Heights|Polk Audio FXia6 Surround|DIY 8cuft Dayton Ultimax 15" powered with a Crown XLS1000
    2Channel Rig Polk Audio LSi9 Cherry| Carver C-1BillD Mod|Carver M1.0t MkII Opt2|Pro-ject RM 1.3|SpeedBox S|AQ King Cobras|AQ Rocket88|
    ISF Level 2 Certified Calibrator
  • did you mount those to the existing box? or just keep disconnect and rip out the old amp and connect the speaker wires to the cleanbox?
  • avr to clean box to crown then direct to the driver bypassing the amp plate. I left the amp plate in just it would keep the box sealed. Moved on since then though
