Best threads for explaining the SDA 2B TL upgradede
geppy1
geppy1 Posts: 3,076
edited August 2013 in Vintage Speakers
What is the best thresd for explaining how to do the SDA 2B TL upgrade? Thanks
Post edited by geppy1 on
    F1nut Posts: 52,008
    edited August 2013
    This is a thread I wrote about it years ago. The pin/blade CRS+ and 2B crossovers are exactly the same.
    http://www.polkaudio.com/forums/showthread.php?40577-SDA-SRS-4.1TL-Upgrade&highlight=2BTL
    A couple of things, eliminate this step entirely;
    (2) .1uF Gen II (replaces the 750pF Silver Mica)
    Use two 20's instead of the 30 and 10;
    (2) 10uF (combine the 30 & 10 to equal the needed 40uF as the largest cap from Sonicap is 30uF)
    Use the 12 watt versions instead;
    Mills Wire-wound 5 watt resistor 5% tolerance
    (2) 2.7ohm MRA-5
  • Schurkey
    Schurkey Posts: 2,122
    edited August 2013
    For any applicable SDA 1 or 2 or CRS or SRS 2 (the ones suitable for the TL upgrade) is there anything more to the actual TL mod that ripping out a 4.4uF capacitor in each high-frequency crossover section, and installing a 5.8uF cap in it's place--and installing the SL3000/RD-0198 tweeters in place of the SL2000s?
    Everything else done to them is just general repair or mods that could be done without changing the TL status--right?
    The TL mod is more involved in the other applicable models of the SRS line, but not in the regular SDA line, or in the SRS 2 blade/blade.
  • geppy1
    geppy1 Posts: 3,076
    edited August 2013
    Thanks Jesse.
    I knew you had done a write up but could not find it for some reason.
    I am not going to do the whole X/O yet. I just want to add the 198s and the 5.8 first. Just to make sure ,the 5.8 goes to the C5 hole and one marked H??
    F1nut Posts: 52,008
    edited August 2013
    Keith, correct the 5.8 goes in the C5 position. You can either drop the 5.8 bottom lead into the bottom C5 hole and run a jumper from E to H or run the 5.8 bottom lead into the H hole. Also, make sure your boards have a jumper in the R2 position.
    F1nut Posts: 52,008
    edited August 2013
    Schurkey wrote: »
    The only Polk approved TL upgrade is for the pin/blade CRS+ and 2B. I know a few folks have done something with other SDA's, but I have yet to see anyone post frequency plots, etc. and until I do, I remain skeptical. Certainly using the RD0198-1 in the top position and the SL2000 or RD0194-1 in the bottom position of the 1C's is far from ideal.
  • westmassguy
    westmassguy Posts: 6,850
    edited August 2013
    I TL'd my 2As, and they came out fantastic. I based it on a long thread, that you participated in F1. My 2As are single Tweeter though, and the Hi-Pass section of the 2A is almost identical to the 2B, with the exception of a resistor in the shunt.
    I would not recommend it for any other SDAs that have multiple Tweeters however, unless there's an approved TL modification.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
    F1nut Posts: 52,008
    edited August 2013
    I don't remember the thread (I'm old...lol), but yeah, I could see that working just fine for the 2A'a.
  • westmassguy
    edited August 2013
    Well I'm 56, so I have my senior moments. It worked exceptionally well, and the only reason I attempted, was because of your input along with a few other senior members. I did a small write-up on it, with and without the resistor. Because of the very different Lo-Pass Section of the Pin//Blade 4th Generation, with different stereo and dimensional woofers, the resistor had to stay.
    When I jumpered it to mimic the 2B, the Hi-Pass was too hot.
  • geppy1
    geppy1 Posts: 3,076
    edited August 2013
    OK Not sure what to do here I did do th 198s and since the Solen 5.6 was avaiable localy I did that Just to see,. and yes things do come out from the behind the speakers and are more upfront. I figured 5.6 was close enough. Now I want to do the whole thing. Cost is a big deal as usual. These are the options I see I suspect anything would be better then stock. What is the best bang for the buck here??
    All Solens $68
    All Clarity PX $112
    Solen (40 and 20) with Clarity PX (12 and 5.6) $75
    Solen (40 and 20) with Clarity ESA (12 and 5.6) $95
    Carity PX (40and20) with Clarity ESa (12and 5.6) $135 ouch??
    pitdogg2 Posts: 27,333
    edited August 2013
    I find the Solens to be BRIGHT or harsh on my ears. Sonicraft too pricey?
    YMMV Keith just my .02
  • westmassguy
    edited August 2013
    I'd go Sonicap/Mills all the way, you won't be sorry
  • geppy1
    geppy1 Posts: 3,076
    edited August 2013
    I went with this as I thought it was the best bang for the buck.
    F1nut Posts: 52,008
    edited August 2013
    Sonicap for the HF would be a much, much better choice.
  • Face
    Face Posts: 14,340
    edited August 2013
    I don't agree with much better. PX series is similar to the SA series, but with voltage capacity. The PX/SA series has a laid back sound to it, meanwhile Sonic Caps have more detail, but aren't harsh or nasal like Solen.
  • geppy1
    geppy1 Posts: 3,076
    edited August 2013
    I hope they are not to laidback
  • geppy1
    geppy1 Posts: 3,076
    edited August 2013
    Well after about 150 hours on the 198s and caps I can say the voices are a little more forward and the speakers sound more transparent. My only concern is the midrange does not seem as thick/rich as it was. Not that 2Bs are rich (like a 1C0 The sound is slightly thinner
    F1nut Posts: 52,008
    edited August 2013
    IMO, what you are hearing is a more balanced sound compared to the 1C's.
