Crossover Location
gkellerman
OK, I've gotten replacement Crossovers for my SDA 2B's. Before I rip anything and everything apart looking for them could someone please tell me the location so I have to do minimal disassembly?
gkellerman@niche-soft.com
Post edited by gkellerman on
Take out the binding post plate (4 screws) on the back of the speaker cabinet, it should be attached to it. Or, you can take out the PR to gain access from the front.Political Correctness'.........defined
President of Club Polk -
I done took those screws out but there are some wires attached to it that are somewhat taunt. There is an Allen Screw head about 6" above that plate. Is it possible the crossover is attached to that?gkellerman@niche-soft.com
Yes, that's it. I couldn't remember exactly were it was, but knew it was right near the plate. It'll be easier to gain access by going through the front.Political Correctness'.........defined
Thanks Nut. Looks like I'll wait until morning to go scrounging around in the garage for the Allen wrench set.gkellerman@niche-soft.com
