Help with replacing RT1000P amplifier
HTguru1982
HTguru1982 Posts: 1,066
edited August 2013 in Troubleshooting
I need to replace an amp in one of my RT1000p's. I have a "new" one that I purchased on Ebay. Is it just a simple swap or...? Some guidance would be nice before I go pulling out the bad one and disconnecting things lol.
Thanks in advance!
Display: Sony 42" LCD
Sources: Harman Kardon DVD-27,
Panasonic DMP-BDT110 blu ray player
AVR: Sony STR-DA2400ES
Amps: Sonance Sonamp 260(fronts),
Kenwood KM-894(surrounds)
Fronts: NHT 2.5
Center: NHT VS-1.2A
Surrounds: NHT Super One
Subwoofer: SVS PB10-ISD
Post edited by HTguru1982 on
  • WLDock
    WLDock Posts: 3,073
    edited August 2013
    Its nothing special....just remove the screws and removed the connecting wires terminals. Best to have something of the same height to rest the bottom of the amp on when you first pull it out. There is not a lot of extra wire so don't pull it out too much with the wires still connected....might pull a wire off the driver.
  • HTguru1982
    edited August 2013
    Thanks for the help. I opened it up and you're right about there not being enough wire. Besides that, it looks easy enough. Thanks.
    Fronts: NHT 2.5
    Center: NHT VS-1.2A
