A9 and DSW PRO 660 wi
So the instructions for the DSW PRO 660 wi powered sub, say that if you use the LFE you should set your fronts to small. I am wondering if that is still recommended when used with a pair of A9's powered by a 2 channel Adcom gfa -555 amp?
Fronts: Polk RTiA9
Center: Polk CSiA4
Sides: Polk F/XiA6
Rears: Polk RtiA3
Sub:Polk DSWPRO 660wi
extras: 2x JBL Monitor 4206
AVR: Marantz Cinema 50
Amp: Hypex UcD400 Class D, 2 Channels
Power Conditioner: Belkin PureAV Home Theater Power Console pf60
Many different streamers, Heos, firestick, apple
Post edited by CinderLyon on
  • nguyendot
    nguyendot Posts: 3,594
    edited July 2013
    It depends on your receiver. Personally I would run those small. Even with your adcom those A9s could take double the power.
    Main Surround -
  • CinderLyon
    CinderLyon Posts: 108
    edited July 2013
    i have a dedicated amp for them.
    Fronts: Polk RTiA9
    Center: Polk CSiA4
    Sides: Polk F/XiA6
    Rears: Polk RtiA3
  • nguyendot
    edited July 2013
    I think you missed the part where I mentioned that. A9s can take 500w+ of power - your amp is not even remotely close to that. As such, I'd run them small unless you have more power to feed them. You can do them large and it will probably be fine except at the top 10% limit.
    Main Surround -
  • fokakis1
    fokakis1 Posts: 36
    edited July 2013
    CinderLyon wrote: »
    Your amp/mains combo is quite capable. I find that I measure flatter freq. response in the bass region with my fronts set to large as compared to small. I would go with what sounds best. If you can, try to take some measurements to see if you can verify what you are hearing.
    Full 8.2 with:
    Onkyo TX-NR818
    Emotiva XPA-3
    Audiosource Amp One/A
    Behringer EPQ2000 w/quietfan mod
    Panny BDP310
    3TB NAS
    Ethereal ESP601R
    Monster HTS 1650
    Epson HC-3020
    120" DIY 1.0 Gain Screen
    Polk Rti A9 fronts
    Polk Rti 6 surrounds
    Polk Rt/Fx rear surrounds
    Polk Rti 4 front heights
    (Phantom center):wink:
    SVS 12's x 2 (DIY passive):eek:
    ATS Acoustics DIY panels
    Harmony 650
    Nostalgia Electronics CCP-510 MovieTime Popcorn Cart
  • CinderLyon
    edited July 2013
    fokakis is that with the double base set on or off with your receiver? Good idea I can test for base response.
    Fronts: Polk RTiA9
    Center: Polk CSiA4
    Sides: Polk F/XiA6
    Rears: Polk RtiA3
  • fokakis1
    fokakis1 Posts: 36
    edited July 2013
    CinderLyon wrote: »
    Double bass set to On. In most cases I see smoother response with fronts set to small. However, in my current set-up my A9's are closer to the front corners than usual so I get flatter response (and better sound) when set to Large/Double Bass On. Your results may very well be different.
    Full 8.2 with:
    Onkyo TX-NR818
    Emotiva XPA-3
    Panny BDP310
    3TB NAS
    Ethereal ESP601R
    Monster HTS 1650
    Epson HC-3020
    Polk Rti A9 fronts
    Harmony 650
  • CinderLyon
    edited July 2013
    ok, I will test both. I like both but get a bit bass spoiled after listening to double on. so testing will be a good way for me to see where the systems is.
    2x svs 12's i am jealous. :)
    Fronts: Polk RTiA9
    Center: Polk CSiA4
    Sides: Polk F/XiA6
    Rears: Polk RtiA3
  • Thorton
    Thorton Posts: 1,324
    edited July 2013
    Placement, room design and personal preference in SQ factor in so much that you'll have to decide what you prefer. In my case, double bass muddied the sound so I have them set to small. I recommend experimenting with placement, crossover (40-80) and adjusting the output. An spl meter made my life easier with final adjustment by ear. I have mine set to small with the crossover at 60hz.
    DAC: Bricasti M1SE
    Pre/Pro: Marantz AV8805
    Subs: 2 - Rythmik F25's
  • CinderLyon
    edited July 2013
    What do you meant adjusting the output, volume? Yeah got a nice spl for that.
    Fronts: Polk RTiA9
    Center: Polk CSiA4
    Sides: Polk F/XiA6
    Rears: Polk RtiA3
  • Geoff4rfc
    Geoff4rfc Posts: 2,838
    edited July 2013
    nguyendot wrote: »
    +1
    After you've run Audyssey, your AVR should set your A9's around 40-50hz since you've got them amped. You have the ability to adjust it how your want after it's saved to play with the settings.
    From what I've heard, your sub is a capable one. Let the sub do it's job and take advantage of the supreme midrange of the A9's.
    Set up:
    Marantz AV8802A - Sources: BRP Panasonic 9000/CDP Emotiva ERC 3 - Display: LG OLED EVO 83 C3 - Amplification: Emotiva XPA-DR3, XPA-6, XPA-2 x 2 - Speakers: Focal/PolkAudio, Mains/2ch - Kanta No2, C - LSiM706, SS - LSiM702, WS - RTiA9, RS - RTiA9, FH - RTiA3 - Subs: Epik Empires x 2
    Cables: AQ McKenzie XLR's from CDP to AVP to amp for 2ch, Emotiva XLR's for the rest - Douglasconnection: Furutech Alpha 36 12g speaker wire for 2ch, Furez 10g speaker wire for the rest - AQ Forest48 HDMI for the display, AQ Carbon48 HDMI from BRP to AVP - VR3 filtered power cables for CDP, BRP and AVP, Emotiva power cables for the amps - AudioQuest 505 power conditioner.
  • CinderLyon
    edited July 2013
    it does not even seem like audyseey chirps at the low ranges on fronts when i setup. For that matter it does not seem that it tests the full range of subs either. In any case it sets my fronts at 40hz which is pretty low anyways.
    Your point about the combo of sub and a9 and mid ranges on them makes some sense.
    Fronts: Polk RTiA9
    Center: Polk CSiA4
    Sides: Polk F/XiA6
    Rears: Polk RtiA3
  • Geoff4rfc
    edited July 2013
    I have the older version of your AVR, the 807. If you listen to your music in "pure audio" mode, it automatically sets your mains to full band so the bass now comes from the A9's.
    If you were to put a stronger amp on your 9's, you would get more bass from them in 2ch.
    Set up:
  • CinderLyon
    edited July 2013
    ahh sure on pure audio and full ranged. I was wondering about that. makes sense. What amp would you suggest? I read good things about emotiva. and the price would have to be under $1000. I really like listening to music on pure audio. it has such a strong crisp image. Direct seems pretty tight as well. Hard to tell the difference for me.
    Fronts: Polk RTiA9
    Center: Polk CSiA4
    Sides: Polk F/XiA6
    Rears: Polk RtiA3
  • Inspector 24
    Inspector 24 Posts: 1,308
    edited July 2013
    A9's with 220wpc Parasound HCA-2003a. Sound great. Plenty of bass to survive on their own for most music in my room, though the HSU fills in things below 40hz very nicely, I run them in large as well for everything, nothing muddy here.
    Of course I should soon see what 350wpc from a HCA-3500 can do with them. Or more importantly going from 60a peak per channel to 120a, 'cause it's the current that matters, not the wattage as I've been advised.
    Up
    LSi15 LSiC - RX-V3000
    Down
    Sim2 D60 - Dragonfly 106" Panny 500
  • Geoff4rfc
    edited July 2013
    I can't speaker for any other amps than Emotiva. I've heard good reports about others such as Inspectors Parasound.
    I'm using an XPA-2 (300wpc) with great results. I'll be getting a second one to run them as mono blocks, they yield 860wpc in bridged mode.
    I got involved with Emotiva due to the low cost, turns out, contrary to some, it's a good quality amp. And before I get a knee jerk reaction from anyone, I didn't say "high" quality, just good quality.
    Set up:
  • fokakis1
    fokakis1 Posts: 36
    edited July 2013
    CinderLyon wrote: »
    I see you have started a new thread in search of another amp. Unless you have a small coliseum, your will not notice a $1000 sound improvement by upgrading your Adcom. Some suggestions to get you a little more bang for your $$ could be:
    -A projector/screen (if you don't have one)
    -A small external amp + speaker pair to add front heights or wides to upgrade to 9.2 with your Onkyo 818
    -Acoustic panels/bass traps
    -Sell the A9's and upgrade speakers
    These are simply suggestions. I'm sure others can think of ways for you to spend your cash as well. Whatever you do... have fun with it! I know I do.
    Full 8.2 with:
    Onkyo TX-NR818
    Emotiva XPA-3
    Panny BDP310
    3TB NAS
    Ethereal ESP601R
    Monster HTS 1650
    Epson HC-3020
    Polk Rti A9 fronts
    Harmony 650
  • Inspector 24
    edited July 2013
    I second acoustic panels. Well worth the money.
    Up
    Down
  • zingo
    zingo Posts: 11,258
    edited July 2013
    CinderLyon wrote: »
    Not necessarily. Sometimes a subwoofer works best when you allow it to pick-up where your speakers drop off, even if that is only 10Hz.
