How to perform a factory reset on the SurroundBar 3000 IHT.
Ghostjumper
Need the steps to reset my sound bar, I think trying to program my cable remote messed up the soundbar programming.
Post edited by Ghostjumper on
Hello Ghostjumper,
Welcome to Polk's forum, you would:
Make sure that the bar is off and in the red standby mode.
The press and hold “Learn” on the front of the bar 5 seconds.
The bar should blink twice to confirm the codes have been erased.
Regards, Ken -
Thanks I will give that a try.
no problem...!
